Dyno Testing and Horsepower Output
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ronman105, Feb 26, 2019.
  1. Ronman105
    Ronman105 Light Load Member
    105
    95
    Dec 30, 2018
    Las Vegas, Nevada
    I have a question for all the motorheads here on the forum. I'm looking at purchasing my first truck and I'm in the testing phase of the truck to see if it's generally a good buy. There's been oil testing done and it's at the local dealership to have a dyno test done in the morning. My question is this: what would be an acceptable horsepower on a 2011 Mack MP-8 engine rated at 465hp? All I can get done here locally is horsepower output and power to the crank so all the other info people get on a dyno readout isn't available to me unless I take the truck to another city. The truck has a lot of miles on it and I just want to make sure there's still some life left in this engine.
    Thanks for any numbers you can give me.
  3. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    I'm assuming you mean the dyno only reads hp at the tires?
    85% of flywheel horse power. 465= 395hp at the back tires
    spsauerland, Oxbow and SAR Thank this.
  4. Ronman105
    105
    95
    Dec 30, 2018
    Las Vegas, Nevada
    Sorry, that's what I meant. Would anything below 85% mean there could be an issue somewhere or that's it's simply a tired engine?
  5. tommymonza
    tommymonza Road Train Member
    4,519
    12,848
    Sep 10, 2013
    S.W. Florida
    Hook it to a loaded trailer. Leave the landing gear down. Pour bleach on tractor tires.
    Make a Contolled burnout.
    Crank landing gear up and approach on Ramp.
    Drop 1st like you’re daddy caught you talking in church .
    Get 2nd like you want to run out of the room
    Search for 3 rd like you forgot where the closet was
    Ahh 4th breath
    Enough breathing into 5th. Run with it. 6 th is right around the corner
    Here we go Breath 7thnnnnnnn
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    I was taught with a 425 engine long ago by a dyno man using simple words. He taught me that hotel power (Alternator, fan etc) steals a few horsepower. Transmission buys a little more. Then the rears and shaft and wheels etc soak up some more horsies. By the time the dyno feels the remaining horsies running on it you probably have lost about 115 or so of them. At cruise and put the foot down you go from base power to maintain say 200 hp to hold 55 and now you want to speed up. You have that 100 or so horses to add to the fight and get speeding up on flat ground. Only now you are fighting the outside air resistance and ground incline etc. That will soak up some more.
    Whatever horses you have all out on that dyno should be better than 70% of what the stamp on the engine output in horsies say. Anything less you probably have a tired engine, or some other problem like no greasing etc. A form of arthritis in bad bearings parts or whatever.
    I used up everything i know about this typing this post I hope it helps.
  7. Ronman105
    105
    95
    Dec 30, 2018
    Las Vegas, Nevada
    Actually it helps a lot and makes a lot of sense. A lot more sense than the post before you...lol. At least I have a ballpark to look at tomorrow when I get the results back. I hope they're decent so I don't have to go back to the drawing board to find another truck.
    spsauerland and x1Heavy Thank this.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,417
    6,430
    Aug 26, 2014
    You do not need a meter to be able to say this blow by is way out of line under load. I would ask about looking at that.
    spsauerland and Hulld Thank this.
  9. Ridgeline
    22,101
    113,189
    What do you mean you don't need a meter?
    To the op...
    A dyno measures the hp at the wheels, it is calculated to figure out what the horse power is at the flywheel. It should be at least 75% of the rather hp, which is good for a high mileage engine.
    Blowby is measured at a full load (which the dyno puts on the engine) and is measured in inches of water. This is as important as the hp rating.
    All the ancillary power drain is meaningless for general purposes, mainly because the dyno fits that all in.
    If you are getting a dyno, and they can't do a blowby or give you the full results, take it somewhere that can, a lot of dealers have bought cheap chassis dyno and charge the same price as one who have good ones and can measure more than just hp and blowby like fueling under a load and general performance.
    BoxCarKidd Thanks this.
  10. BoxCarKidd
    4,417
    6,430
    Aug 26, 2014
    Even saw a You Tube of someone using clear plastic hose with water in it making marks on the hose. If all you get is HP output that is a problem to me.
    Ridgeline: Maybe I said that wrong but to me that is just as important as HP. Thanks for the additional information.
    spsauerland Thanks this.
  11. Ronman105
    105
    95
    Dec 30, 2018
    Las Vegas, Nevada
    Thanks for the input. I went ahead with the dyno just to get a baseline idea of what to work with. They said it's putting out 404 horsepower (87% of rating) and less than 1" at the crank if I heard her correctly. To be honest, I'm not really clear what she meant by that.
