Dynasys oil pressure switch
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by JonJon78, Dec 7, 2019.
  1. JonJon78
    JonJon78 Road Train Member
    7,040
    37,541
    Jul 1, 2018
    Not much info out there on Dynasys APU. I have the Gen II with the CAT engine.
    If you ever get an alarm on your Dynasys indicating "Low or No Oil pressure" and the unit shuts off heres the part you will need to fix it.
    About a 5 minute fix once you get the part. Pretty much plug and play. You dont need to be a mechanic to fix it... The only tool needed is an adjustable wrench. Got the part online for $30
    20191128_091529.jpg My finger is on the "Oil pressure Switch" top right of engine.
    New Part #
    Old and New switch
    New Switch installed.
    D.Tibbitt Thanks this.
  3. Wespipes
    Wespipes Road Train Member
    1,037
    1,815
    Jul 14, 2019
    Would you recommend this apu? Cany find many reviews. I'm supposed to get mine installed next week at boomers in OK
  4. JonJon78
    7,040
    37,541
    Jul 1, 2018
    Yes. Boomers is where I purchased mine from.
    Wespipes Thanks this.
  5. Kz99
    Kz99 Bobtail Member
    Jan 17, 2022
    I'm currently dealing with this, the engine won't auto start sometimes due to "low oil pressure" even though the oil was just changed, and eventually goes into "battery charge failure" after a few failed attempts to auto start . Thanks for putting this info out here.
    Do you happen to know some reasons why these switches falter?
    JonJon78 Thanks this.
  6. JonJon78
    7,040
    37,541
    Jul 1, 2018
    Not sure. Believe mine failed after 2 years of use, don't recall the exact number of hours on the APU.
  7. free2fly973
    free2fly973 Light Load Member
    95
    11
    Mar 9, 2012
    Oklahoma
    So your dynasys apu died completely after 2 yrs?
  8. JonJon78
    7,040
    37,541
    Jul 1, 2018
    No the oil pressure switch pictured above went bad. Ive had the same Dynsays APU since 2017. Still running good...
    Dave_in_AZ and free2fly973 Thank this.
  9. free2fly973
    95
    11
    Mar 9, 2012
    Oklahoma
    I'm trying to decide if I should get a dynasys or tripac. Dynasys a person with mechanical skills should be able to fix most things. Tripac sounds like codes are vague and still going to get part from dealers or blessed places only. And are limited and limited places?
    Would you buy the dynasys again know what you know now? Reliable?
  10. Chieftains
    Chieftains Medium Load Member
    362
    896
    Jul 18, 2021
    What is the price difference
  11. Dave_in_AZ
    369,826
    I use TriPac. The engine itself is pretty bullet proof and easy to PM.
    It's the rest that goes teets up after awhile. And what I've learned is that after so many years when the stuff starts to fail.....just overhaul all of it, not the engine, then you're good for several years.
