Recently my company installed 'Green Roads' Technology to our trucks, and what a nightmare it has been. We slip seat trucks so different trucks act differently in situations, and the Safety dept. it seems has been on a track of saying one thing and doing another since installing this. For example.
They use a different service to monitor logs, and DVIR's to ensure that we are compliant with regulations laid out in the FMCSR. Two years ago they got rid of the log books that had the DVIR with every log sheet, noting that the DVIR was to follow the truck, not the driver. Now we have been told that starting on 12/01/10 we must fill out a DVIR even for days off, noting that 'off duty' status on the DVIR. I have two questions about that.
1. This requires me to carry a seperate DVIR book. Is that illegal in any way?
2. DVIR must be logged, how would one reset if a DVIR has to be logged every day?
Thanks for your input in advance.
j-mac
DVIR regulations
Discussion in 'Trucking Industry Regulations' started by j-mac, Nov 8, 2010.
A DVIR should not be done on a off duty day!
§396.11 Driver vehicle inspection report(s).
(a) Report required(1) Motor Carriers. Every motor carrier shall require its drivers to report, and every driver shall prepare a report in writing at the completion of each days work on each vehicle operated, except for intermodal equipment tendered by an intermodal equipment provider.
And there is not a problem with a seperate DVIR from the log. Nothing says they have to be part of a log book. -
And my question about the DVIR books was that there is one in every truck that follows that truck, if I have to do DVIR's on my days off, then I have to carry a separate book. Is this illegal?
j-mac -
that's what i would do. -
Correct.... because if you're off duty and you log the d.v.i.r. than that means you were on duty which means that you lied in your logbook about being off duty. Ok I see what you're saying now... I guess you can turn one in and write 'off duty' on it so it matches your off duty status in your logbook. This would make sense. The same as the logbook where you write off duty in the remarks area. -
You are also affirming a false statement. What if someone else drives the truck on your day off after you proclaimed the truck fit, and the other driver gets a ticket for the truck. Or, you signed off on the truck, a tire goes flat, an air line ruptures, an air bag burst, ect... whilen sitting in the lot. You are legally on the hook because you signed off as to the truck being OK without having seen the truck. The company needs to consult with the DOT and get their facts straight.
Yeah I read it again and I think you have a point.
