Dumping Air Bags When Coupling/Uncoupling
Discussion in 'Experienced Truckers' Advice' started by mjfmjf, Mar 2, 2012.
  1. mjfmjf
    mjfmjf Light Load Member
    71
    13
    Jan 23, 2012
    Harpersfield, Oh
    I am confused as to the proper procedure when coupling/uncoupling. Should the air bags be dumped on the tractor and or trailer?
  3. bonder45
    bonder45 Road Train Member
    1,803
    5,445
    Oct 2, 2011
    Williston, ND
    It's really personal preference - I usually dump tge trailer air if I'm doing a full load / unload but if it's a small drop there's no need. I only drop the truck air if I'm dropping a 40,000lb load.
    mjfmjf Thanks this.
  4. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    With my own equipment I drop landing gear, unhook lines, pull pin latch, pull truck forward about a foot so king pin clears fifth wheel, drop air on drives then pull clear of trailer. I do this to avoid scraping off all the grease.
    Not for the lazy or those in a hurry.
    scottied67, poppapump1332, SHC and 2 others Thank this.
  5. Giggles the Original
    Giggles the Original Road Train Member
    the only time i dump air bags to couple (tractor only ) is if i cant get underneath the trailer...then when dropping yeah i always dump air bags on the tractor . you wanna make sure tho that you still always only pull forward a little, when you are ready to pull out from underneath a trailer and make sure the frame of your fifth wheel area is still under the edge of the trailer to make sure the landing gear on the trailer is gonna hold, then after a few seconds and you see all is fine, you can pull on out........on the trailer....never, only when loading if the dock is too high....thats how we do it....
    mjfmjf Thanks this.
  6. Everett
    Everett Crusty Shorts, What???
    2,095
    6,401
    Oct 20, 2009
    Hampton,Ia
    or you can just go to u tube and wacth how its done too :yes2557:
  7. Giggles the Original
  8. Kittyfoot
    Kittyfoot Crusty Ancient
    2,092
    3,056
    Sep 21, 2009
    Sorrento, Louisiana
    Dropping airbags on the tractor as has been described. If you have an air-ride trailer with a dump valve dump em before you wind down the dollie legs to avoid torquing the leg shaft.
    SHC Thanks this.
  9. TheRoadWarrior
    TheRoadWarrior rocking-n-rollin again
    1,058
    3,154
    Dec 6, 2011
    South West
    LOL dang it Kitty ya beat me too it... i was just gonna say the exact same thing..lol...
  10. Kittyfoot
    2,092
    3,056
    Sep 21, 2009
    Sorrento, Louisiana
    Cool, great minds think alike.:biggrin_25520:
    I know just about everybody here has had to try cranking a set of dollies under stress (and usually in high gear).
    Please, new guys, when you drop a trailer pop the crank in low for a few turns after the pad touches the ground.
  11. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    I do the same, but I do it to not over-extend my bags (I've had one blow on me before) plus I like to make sure the trailer is not going to sink into the pavement/gravel before I pull away.
    And of you have a tanker, you ALWAYS want to dump the bags on the trailer, or else it will end up going nose first into the pavement most of the time after the legs fold under it.
    wis bang Thanks this.
