I just started with my dump truck business i have a tandem can only carry 12 tons and i have so many questions i am currently working for someone as an owner operator. I am currently located in San Antonio Texas and want some pointers on how much to charge for material and how can i start my own dispatch or does anyone know of a broker or dispatching company i could use here in San Antonio
I am a beginner and i need advice how to take my business to the next step and learn how to land contracts thank so you much in advance
Dump Truck
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Dalia01, May 17, 2018.
Page 1 of 5
dump trucking doesnt pay squat in the san antonio area
RockinChair Thanks this. -
You wont be getting much. So bags of money to lay on is out.
You will find a way to put way more than 12 ton in the bin, don't worry about that. MR stone will be sure to take care of you at the Slate and Quarry where Fred works to this day. Its weight limited bridges you need to worry about.
You also need a place for that truck where you either do not have neighbors around because there are times you are spraying diesel into the bed for blacktop example to let it sit and drain a overnight towards morning partially tilted. (Spray bottle from garden center with a couple gallons at most for the whole bed when empty. then a flat edge shovel to get the stubborn bits off in the morning)
You will need a place to shop that truck. Sooner or later that work will munch into your revenues. Especially once DOT got ahold of you now and then. If they see that you are putting on shiny new spring hangers and so on and make a effort to stay 100% mechanical they will treat you nicer.
Then there is matter of tags, stickers and registration along with fuel and payroll for yourself or driver you hire. If you put on a trailer to that pintle you will be limited in how to load that trailer. But all is well. Especially if you can get a pickup dually for a tool truck to toss everything else into it.
And it spirals into something you cannot let go of in your life at some point. It's literally holding a tiger by the tail.
Have a nice time.Caterpillar Cowboy and Dalia01 Thank this. -
There is no work for tandem axle dump in most states. Customers want maximum tonnage. In pa that’s a triaxle hauling 23 and a half tons. I make 800-1000 dollars a day and same goes for rest of owner operators here. Alls it takes is signing on with big local construction company’s locally hauling quarry materials, blacktop or hauling dirt. Like I said though, nobody will hire a tandem axle anywhere.
Oxbow Thanks this.
Our big Mack had 300 plus gallons being a former over the road truck in her day and there were times it became a tanker keeping the paver and such going.
As far a the looks, don't let that bother you. That tells me you are potentially living in a region where people need a churching up with what a working man needs to do with his fuel now and then. If you want to see the looks, check out the Manassas VA Sheetz as I work my 18 wheeler around all of the people getting gas to the one side to get coffee and food off US 15. Been going there all my life with the exception of my time here at home in Arkansas. -
I have a question about tags permits when becoming a O/O in PA. Do you think you could answer some of my questions? Would much appreciate if you could help!
Thank you -
Hey I’m a driver from PA looking to become a O/O in the philly area. I was wondering if you could help me some question I have able tri Axle permits and tags. If you can that would be much appreciated.
Thank you
Page 1 of 5
