dump truck with backhoe and trailer
Discussion in 'Trucking Industry Regulations' started by sammy_74, Feb 13, 2016.
  1. sammy_74
    sammy_74 Light Load Member
    55
    5
    Nov 9, 2015
    Hey guys I had a question. On Tuesday I am going to be driving a dump truck with a backhoe trailer. I was wondering if I have to go through the Scales with that. Dose anyone know I have my class a but this is a regular class c license truck and I wasn't sure if I still had to. And if I drive the dump truck alone do I have to go through it. Thanks it might be a dumb question but I was just wondering.
  3. Fredy
    Fredy Light Load Member
    88
    15
    Feb 11, 2016
    Washington, D.C
    What state is this? Here in Maryland, any vehicle over 5 tons (with some exceptions) is required to pass through scales. With a dump truck and a trailer of any sort I think you would have to go through.
  4. sammy_74
    55
    5
    Nov 9, 2015
    I'm in california one of the more sticker states
  5. Fredy
    88
    15
    Feb 11, 2016
    Washington, D.C
    Ok, and is this commercial? If yes, then yes you would have to stop through. I got this information from
    http://www.dot.ca.gov/hq/traffops/trucks/weigh-stations/stopping.htm
    "GVWR under 11,500 pounds, unladen weight of less than 8,001 pounds, and open box-type bed not exceeding 9 feet in length -- NO.
    GVWR 11,500 pounds or more, unladen weight 8,001 pounds or more, or not equipped with an open box-type bed not exceeding 9 feet in length -- YES
  6. sammy_74
    55
    5
    Nov 9, 2015
    It's a open top dump truck, the boss said it's a class c truck so I don't need my class a license but since me never driving a dump truck with trailer and backhoe on it I was just wondering
  7. Fredy
    88
    15
    Feb 11, 2016
    Washington, D.C
    Sounds good, I think better safe than sorry. Have a good one
    sammy_74 Thanks this.
  8. realdesertkickin
    realdesertkickin Heavy Load Member
    925
    752
    Nov 18, 2013
    Tustoned Arizona
    In my nook of the universe, the scales are for "all commercial vehicles"
    Just be safe than sorry dood...Or go fix that piece of crap right away!!!
  9. clausland
    clausland Road Train Member
    1,933
    11,067
    Dec 5, 2014
    North Woods
    In the modern age, I would guess yes, but I have to laugh.....Years ago, we would simply hook the front bucket over the truck tailgate and exert down pressure, lifting up the front of the machine.....Down the road we'd go, no problems....
    thejackal Thanks this.
  10. Bdog
    Bdog Road Train Member
    1,057
    877
    Nov 6, 2014
    There is no way in heck it is a class c truck. Well maybe the truck is I used to own a class c dump truck but once you hook a trailer to it with a backhoe you are most certainly over 26k with a trailer over 10k and thus you need a class a. My backhoe is a medium sized one and it weighs 17-18,000lbs. The trailer weighs around 6,000. The truck is probably 12-14k empty. You likely will be driving a 35,000lb rig. Yes class a, logs, scales, etc just the same as if in a semi.
  11. keitht
    keitht Light Load Member
    115
    224
    Feb 23, 2012
    USA
    Exactly correct. With a trailer, you will be a class A combination.
