Dump tri axle and pup trailer
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Rodeo_Joe, Apr 29, 2012.
  1. Rodeo_Joe
    Rodeo_Joe Light Load Member
    183
    17
    Oct 24, 2008
    Blackstock, Ontario
    I've been drivin for 12 yrs now tractor trailer, and triaxle dump trucks, crane trucks. Now monday my company is throwin me in a tri axle dump and triaxle dump pup. any advise things to watch for? tips for jackknifin to dump lead in tight areas?
    thanks
  3. Bikerboy
    Bikerboy Light Load Member
    299
    183
    Apr 1, 2008
    Canada
    Always dump trailer first and don't pinch hoses when jack knifing dump all air ride while while dumping
    Rodeo_Joe Thanks this.
  4. melpromud
    melpromud Medium Load Member
    463
    114
    Jan 29, 2010
    camden ny
    Untill you learn your equiptment get out and look while jacking the trailer around. Over jacking may bend the toung, break the pintle hitch or cut air, electric, and hydro lines. Try to jack the trailer to the drivers side unless its not possible and pay close attension to the blind side while doing so. One thing that will happen is the trailer will lean as is skirts the edge of the pile that came from the truck as you pull forward. Watch out for thing like trees, polls, or buildings that are close to the trailer as you pull away from the pile. I once dumped salt it a salt dome close to the door. Dumped the trailer first then jacked the trailer inside the dome and dumped the truck just inside the door. As I tried to pull out the trailer came up on the pile from the truck and wouldnt clear the door frame. Luckly I seen it before I hit the building but the only way out was to shovel the pile out of the way of the trailer to clear the door. 2 hours later I was out.
  5. Rodeo_Joe
    183
    17
    Oct 24, 2008
    Blackstock, Ontario
    2 days down bout a dozen loads no troubles.[​IMG]
  6. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Worst case do you have to dump the trailer drop it. Dump the truck ,rehook and go. Does not sound like fun.
  7. Rodeo_Joe
    183
    17
    Oct 24, 2008
    Blackstock, Ontario
    apparently I have to do that at c ouple of my drop locations because there yard isn't big enough. I'm supplin a bunch of lil garden centres, sadn and gravel yards with soils mulches, an gravels for resale.
