Dump trailer tires
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Thetrashnoob, Mar 30, 2024.
  1. Thetrashnoob
    Thetrashnoob Light Load Member
    262
    45
    May 30, 2019
    I’ve inherited a 28ft aluminum tandem axle dump trailer, it has been sitting for a few years. It needs new tires. It has 11r24.5 tires on it currently. my mechanic recommended cheap tires since they never last.
    I found some speedmax ss622 steer all pos 16ply tires.
    I am wondering if 16ply will work? Or I need something different? Any other brands to look at?
    the set of 8 is just over 2k plus mounting etc.
  3. abyliks
    abyliks Road Train Member
    3,746
    8,694
    May 2, 2010
    ludlow MA
    Cheap tires don’t last…
    We have been having good luck with kumhos on trailers, 1 low bed and 1
    Dump legal for 99k is running them on 11r24.5
    Diesel Dave Thanks this.
  4. Diesel Dave
    8,522
    23,455
    Jan 20, 2010
    Hesperia, Ca.
    You can’t beat 2k for 8 though. But I know the saying, “You get what you pay for”…..
  5. Thetrashnoob
    262
    45
    May 30, 2019
    Yeah I know cheap tires don’t last, I know they are going to get torn up in the quarries so trying to get away on the cheaper side without it bitting me.
  6. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    16 ply is what you need… maybe not that brand tho
  7. Thetrashnoob
    262
    45
    May 30, 2019
    I’m not really sure what brands there are and what is good/bad. Open to suggestions
  8. AModelCat
    154,368
    My old man ran China tires on his logging trailers. Why pay premium dollar for tires that are going to get cut & gouged up long before they're worn out?
    Last Call, kwswan and Diesel Dave Thank this.
  9. abyliks
    3,746
    8,694
    May 2, 2010
    ludlow MA
    Most quarries I’ve been to are pretty well maintained, you can either back around or kick any large debris out of the way, landfills are a bit harder and usually destroy a tire before it wears out, I’d be more worried about tight turns and any highway travel you do have while in transit then on site, but try the $2k set, cheap enough and worst case you go with something else on the next set if they only last 20k miles or start blowing out going down the road
  10. Thetrashnoob
    262
    45
    May 30, 2019
    that’s what I am thinking give the tires a try, I don’t really know brands and such so I’m trying to do some research but I need to order them soon. Don’t see the need to spend 5k on a set of tires but also don’t want to spend 2k and they blow the first trip.
  11. abyliks
    3,746
    8,694
    May 2, 2010
    ludlow MA
    Kumho, sumitomo, Hercules (which are either Firestone or coopers can’t remember), double coin, you have a few cheaper side of mid grade tires as well,last set of kumhos were $3100 for 8 and I swapped the casings for mounting
    Edit: $3100 was low 22s for my fridge, want to say the tall 24s for the bucket were 35 or 3600 IIRC
