Dump trailer coming down slow
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Loaderlou, Aug 4, 2020.
  1. Loaderlou
    Loaderlou Medium Load Member
    342
    130
    Feb 24, 2014
    Hi all. I have an east dump trailer hooked up to my 379 pete. Trailer goes ip fine, well maybe a little slow, but takes forever to come down. My Ball valve is open all the way and I squirted half a can of Pblaster on the pump mechanism and worked it in and out. Is there an adjustment anywhere on the pump or anything else I can try
  3. okiedokie
    okiedokie Road Train Member
    11,677
    84,541
    Jun 13, 2011
    PNWET
    Hydraulic tank vent cap plugged?
    Loaderlou Thanks this.
  4. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    When was the last time the hyd filter was changed?? If I recall right they filter the oil going into the tank not coming out and into the pump.
  5. NightWind
    NightWind Road Train Member
    2,616
    18,579
    Nov 11, 2006
    Sunny South, AL
    Check the filter on the tank, the bleeder valve on the cylinder and make sure the hydraulic lines are tight.
  6. Loaderlou
    342
    130
    Feb 24, 2014
    Thanks guys. I have a 3/4” ID hose as a vent. Did notice a small puddle below it the other day. I’ll check that out. I don’t have a filter on my hydraulic system, it’s basically a free flow back to the tank
  7. Loaderlou
    342
    130
    Feb 24, 2014
    My piston is the original from 2005. 50 ton hoist and the collars are weeping a bit. Maybe sucking air?
    NightWind Thanks this.
  8. NightWind
    2,616
    18,579
    Nov 11, 2006
    Sunny South, AL
    Sounds like the packing is weeping. Some times the auto bleeder valve on the top of the cylinder gets stopped up and needs cleaning. I'd check the filters and lines. You'd be surprised what a loose line will cause. When its loose the valve can't open or close correctly and that causes the entire system to slow down (like a finger in a drain). I'd also undo the butterfly valve and reseat it.
  9. Loaderlou
    342
    130
    Feb 24, 2014
    You know come to think of it, I just had the unit apart and I could swear I tightened the butterfly with a hammer. I will go over everything again. Thanks to all of you.
  10. NightWind
    2,616
    18,579
    Nov 11, 2006
    Sunny South, AL
    Some times that stupid butterfly doesn't seat correctly and you have to undo it and reseat it. Let us know what it was if you don't mind please.
    blairandgretchen Thanks this.
