Dually wheels came of trailer axle.
Discussion in 'Trucking Industry Regulations' started by Zooy, Jan 11, 2020.
  1. Zooy
    Zooy Bobtail Member
    Hi. Left, rear dually wheels came of trailer(flatbed). Trailer is empty. I got the wheel, found forklift to put it up on the trailer, secured it. Secured axle to the trailer with a chain. What is the regulation that talks about that? Can i go to my shop that is about 700 miles away, trailer is empty. Thanks
  3. Cattleman84
    Cattleman84 Road Train Member
    9,871
    70,312
    Nov 1, 2017
    The Sticks, Idaho
  4. spyder7723
    spyder7723 Road Train Member
    15,467
    25,010
    Mar 31, 2013
    sarasota, fl
    Its begging for an inspection but as long as that axle is secured up its perfectly legal.
    Cabinover101, Zooy, MACK E-6 and 5 others Thank this.
  5. MACK E-6
    48,130
    219,670
    How’d the wheels come off? Ran the hub dry?
    I hope not, because that’s a good way to get somebody killed. :eek:
    truckerdave1970 and Cabinover101 Thank this.
  6. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    If you can get the axle chained up off the ground you're good to go.
    Trailers and trucks roll around empty with 1 axle up in the air and one axle on the ground all the time.
    Hopefully a scale won't hassle you for inspection though with that left axle.
    Cabinover101 Thanks this.
  7. Inspector
    Inspector Bobtail Member
    41
    29
    Dec 21, 2013
    Upper Plains
    You are allowed to temporarily chain up the axle to get to a repair facility as long as it does not cause an overweight issue. There is no set amount of allowed travel miles to get it to the shop.
    Hulld and Accidental Trucker Thank this.
  8. truckerdave1970
    truckerdave1970 On Probation
    2,987
    3,289
    Dec 15, 2008
    Rochester, NY
    I hope the other hubs had oil in them! sounds like someone has been neglecting their pre-AND post trip inspections.
    just sayin'
  9. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    Is this a Hotshot trailer by chance.
