Dual antenna issues
Discussion in 'CB Radio Forum' started by gmaan03, Dec 6, 2016.
  1. gmaan03
    gmaan03 Bobtail Member
    I have dual Fire stick antenna with a split cable I purchased as a package from Rightchannel. I can tune each antenna to around .75 to 1.1 but when I hook up both my SW meter goes to 3. What gives?
  3. Bout Z
    Bout Z Light Load Member
    275
    1,149
    Mar 14, 2015
    so. ohio
    Need more info...
    are you useing rg59 75ohm coax?
    Rg8 or rg58 will not work for a dual configuration.
    Are you useing a 50ohm dummy load on one side to set swr?
    ex. connect dummy load to right side coax, set swr on the left side antenna. Then switch... connect dummy load to left side coax, set right side antenna.
    bored silly Thanks this.
  4. rabbiporkchop
    9,688
    6,561
    Feb 9, 2012
    Wapwallopen, Pa
    Use Antenna analyzer. Tune both simultaneously. Much easier that way. You cut them too short. Time to start over.
  5. Bout Z
    275
    1,149
    Mar 14, 2015
    so. ohio
    Easier? Sure, if you have access to one, or the means to purchase one, and the ability to use and undrrstand one.
    While Ill agree, an AA is a very handy weapon to have in your arsenal, if you are building your own antennas, expierimenting with different antenna configurations, etc... but it isnt a cost effective tool for the avg cb user/trk driver who is using trk stop gear, and simply wants a 'plug n play' set up. (Note: not bashing trk stop gear, or anyone who uses it)
    I find a field strength meter , which no one seems to use anymore, a handy companion to a reliable swr meter, for the avg cb'er to use setting up a mobile antenna. And much more cost effective as well. Jmo
  6. Ridgeline
    22,854
    126,547
    Let me ask you this, how much would a person pay for a good SWR meter?
    I haven't bought one in 30 years, crap close to 40 outside of the used classic ones like Birds and Diawa.
  7. Bout Z
    275
    1,149
    Mar 14, 2015
    so. ohio
    Probably $15 up to $150 new.
    You can pick one up at a trk stop for $15-20, maybe even less. Some of the newer mfj's, diawas, comets etc will go for $100 +
  8. Ridgeline
    22,854
    126,547
    I was talking about the typical CB ones
    Thanks for the answer, I've got to get out more often, this sucks being restricted.
  9. rabbiporkchop
    9,688
    6,561
    Feb 9, 2012
    Wapwallopen, Pa
    $10 for a cheap one $25 for a fancier one at a truck stop
  10. rabbiporkchop
    9,688
    6,561
    Feb 9, 2012
    Wapwallopen, Pa
    SWR meters are completely useless for an antenna that's resonant at a frequency outside the capability of the persons radio.. most radio shops will check it for free with an analyzer hoping to make a sale
    bored silly and Diesel Dave Thank this.
  11. bored silly
    bored silly Road Train Member
    2,714
    656
    Jul 1, 2016
    they like to run dual antenna setups out here in California where I'm at that's 4 sure... just saying I'm bored out here driving in this 55mph state
    Bout Z and rabbiporkchop Thank this.
