DTC codes
Discussion in 'Volvo Forum' started by Broke_as-hell, Jan 26, 2021.
  1. Broke_as-hell
    Broke_as-hell Bobtail Member
    2015 Volvo truck D13
    DTC p24570
    P112100
    P040B64
    P040100
    P20EE00
    Can some one tell me what they mean
  3. thetransporter123
    thetransporter123 Bobtail Member
    22
    12
    Jan 5, 2013
    P20EE00 DTC Fault Code
    Code Meaning
    The efficiency of the SCR NOx catalyst is below the threshold (row 1)
    P04 codes are egr related
    P245700 Coolant efficiency of the exhaust gas recirculation system is below the threshold value
    I would get a laptop from ebay or somewhere with jpro and volvo tech tool on it and a nexiq usb2 interface and you can figure all this out without going to dealer everytime. And don't get the 500$ laptop with software on it. It's all pirated and will not work properly. The real ones cost a bit more but you will be much happier with it.
  4. Truckwork2461
    Truckwork2461 Bobtail Member
    47
    14
    Feb 10, 2021
    Egr system issues. Need to pull off egr cooler outlet piping and check if cooler is clogged up. Check your turbo’s range of motion. Egr valve, egr diff pressure sensor. All possibilities.
  5. Jacoooooooo
    Jacoooooooo Heavy Load Member
    742
    1,049
    Oct 20, 2013
    I have most of these codes and I noticed boost from turbo barely getting to ~22 psi instead of the usual ~35psi under full throttle. It’s also intermittent, sometimes it gets thru to regular boost. What am I dealing with? Thanks in advance.
  6. Cattleman84
    Cattleman84 Road Train Member
    9,869
    70,289
    Nov 1, 2017
    The Sticks, Idaho
    Codes aside... Just going off what you described with your boost issues. I would say you are looking at cam and rockers problems, my truck did that same thing a year ago and had a few of the same codes youre showing. It was a bad cam and exhaust rockers.
    Jacoooooooo Thanks this.
  7. Jacoooooooo
    742
    1,049
    Oct 20, 2013
    Meaning a rebuild?
  8. Cattleman84
    9,869
    70,289
    Nov 1, 2017
    The Sticks, Idaho
    I cant remember if they had to do a full bebuild or not...
