Dt466e fuel rail gasket replacement
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 704mover, Dec 23, 2020.
  1. 704mover
    704mover Light Load Member
    60
    22
    Mar 8, 2018
    I've got an oil leak from under the driver's side engine cover. It's about a 4" tall, bolt on cover that runs the length of the engine behind the air compressor. Engine was covered in oil so after steam cleaning. We watched it while keeping the rpms at a driving level for a few minutes and found the seep. What's involved in changing the gasket? Is it just a cover gasket or is there more to it like orings and such under it? I think our international 4300 is a 2003 model. Thanks
  3. Inderjit
    Inderjit Heavy Load Member
    716
    704
    Sep 17, 2017
    Replacing the gasket requires disconnecting an oil line and two fuel lines.
    The fuel return line is at the rear of the cover or high pressure rail.
    Make sure and clean the area well before you take it apart. The high pressure rail supplies high pressure oil and fuel to the injectors. Cleanliness is very important.
    Bolts are torqued from the center out to Going from memory 18 foot lbs.
  4. 704mover
    60
    22
    Mar 8, 2018
    I'm trying to source all gaskets needed before I start. Is it just the cover gasket or is there something else inside the cover to replace? Thanks
  5. Inderjit
    716
    704
    Sep 17, 2017
    Just the cover gasket and the grommets for the fuel lines.
    You may have to take off more than one of the fuel lines so
    it might be a good idea to have six grommets for all three lines.
    704mover Thanks this.
  6. pup
    pup Light Load Member
    252
    256
    Dec 3, 2011
    n.h.
    The manifold you're removing is heavier than it may appear. I've had some that required the gasket surface to be resurfaced. An automotive machine shop should be able to do that if needed. There are threaded plugs with orings on each end you'd want to remove to clean out any debris. Like Inderjit says cleanliness is extremely important
    Flint1 and 704mover Thank this.
