Hello! I am interested in purchasing my own trailer soon. I have contemplated the idea of buying a reefer unit and running dry freight in it when the market/location dictates, but I have seen some posts that suggest that running dry freight in a reefer van is ill advised. I can't understand why it would be a problem. Am I missing something? Any help is appreciated.
Dry Freight in a Reefer Van?
Discussion in 'Ask An Owner Operator' started by jldilley, Oct 18, 2013.
i do it half the time... never heard of any problems or concern
jldilley and Skydivedavec Thank this. -
Only issue that may come up is weight.You'll be a little heavier than a dry van but not enough to be a concern.I've done it plenty and it was never an issue
jldilley Thanks this. -
Issues are: weight, volume is less, lower height inside, some are worried about odors, a refrigerator smell is how some put it. floor loading has been addressed in some specialized cases, but other cases like bare roll paper, are a wood van floor only. Less able to secure the load from shifting(can't use locks nailed down).
I have heard of a wood floor reefer, but haven't seen very many, and the loss of space inside would still be a problem.
We quit hauling short back hauls for the most part, but the last one I spent hours and phone calls on, refused to load a reefer, had to be a dry van and I never found out why. I was just about there when the broker called and asked if I had a van, and she had worked with us since before I was there, so sometimes, it is a surprise to everyone when you show up with a reefer.
Weirdest load was 8 foot squares of steel plate, several men with multiple pallet jacks got it in and situated to spread the weight.heyns57 Thanks this. -
In addition to the reasons 25 stated occasionally the moisture content or residual moisture in a reefer is the reason for Dry Van only loads. Had a contract with a few hay farmers and if you were to have used a reefer on it you would have never gotten all the hay out of the channels, etc...even if you spent three weeks with a pair of tweezers meaning you conveniently would get rejected from the next 8 food grade only places you go to. The roll stock paper comes to mind as well.
25(2)+2 Thanks this. -
We loaded a little roll stock, but it was on thick pads of honeycombed heavy cardboard, and, like I said, we quit doing those short hauls.
You can blow it out with an electric blower or a couple of lengths of air hose hooked to the glad hand with an air gun, but it's still a pain to clean a duct floor without a washout, and even sometimes with a washout.
The moisture thing can be an issue, too. -
That's "washout" as in go to the streakin' beacon 'n pay em' about $30 to get the crud out. You can get a reefer trailer deodorized as well... but a can of ground coffee works well for that too.
When freight is slow, we go over to the dry van loads all the time. Never had a problem. Have a load where moisture is a deal? Set you reefer on 32-degrees, high air. That'll get the moisture out.FLATBED and VisionLogistics Thank this. -
Sorry to hijack the thread - 25, we used to do roll stock as well from one side of Atlanta to the other, occasionally a few times a day at $350 a piece added up. Clearly after this I too, stay clear of roll stock. Tried to PM this photo to you but couldn't figure it out. -
So it looks like there is little cause for concer. Thanks for all the input.
Old reefers had wood floors.
