Dry bulk cement
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Jordysmash, May 5, 2021.
  1. Jordysmash
    Jordysmash Light Load Member
    81
    71
    May 28, 2018
    There’s a lot of jobs I see that are hauling dry bulk cement but as far as I’m aware it has silica and you are exposed to a lot of the dust loading or unloading. Is this true? If so do they have safety practices that prevent you from breathing in the dust?masks? Sorry if this is a stupid question but I’ve always avoided this line of work because of that
  3. rbrtwbstr
    rbrtwbstr Road Train Member
    3,329
    7,589
    Jul 11, 2012
    in the bush somewhere
    It can be dusty at times. Loading is probably the worst dust you'll experience. Especially if you're loading at any plant near Allentown, Pa. Those plants are ancient and poorly maintained.
    Unloading normally isn't bad unless the customers bag house is junk.
    I do three loads a day, been doing it 10years or so. Haven't had any ill effects yet. But I do occasionally throw a respirator on if it's bad.
    I worry more about hearing loss. The blowers and the trailers are rather noisy. Use hearing protection!
  4. wis bang
    wis bang Road Train Member
    3,348
    3,917
    Jan 12, 2011
    Levittown, PA
    Hercules, Stockertown, PA had two 'Quonset hut' shaped arched buildings tall enough to have cranes inside. One collapsed and after they shoveled off the dust the other one became 12 feet taller...leaving after dark on rainy nights you could tell they opened the stacks.
    You could see the particulate falling with the rain and the surface of the car felt 'sandy'...that was the early 70's after air pollution controls started.
    Now growing up, in the 60's when you shopped down town, no matter the color you could always tell a car from Bath, Nazareth, Copley, any town where the cement mills were working BEFORE the clean air act by the grey dusty look. Homes near the plants looked that way too..
    pathfinder1361 and rbrtwbstr Thank this.
  5. Jordysmash
    81
    71
    May 28, 2018
    Are there any safe practices you can use to reduce inhaling all of that crap?
  6. rbrtwbstr
    3,329
    7,589
    Jul 11, 2012
    A respirator. That's about it. And I mean a real respirator, not one of those paper masks.
    I have one I keep in the truck, but I rarely need it. If you're doing the job properly and not blocking the trailer up when unloading, and the dust collection systems are working properly, the dust shouldn't be an issue. Most of the places I deliver to are in stone quarries. And the dust that settles on the truck is usually from the dump trucks passing by.
    But, as I said, some of the places I load at, a respirator is a good idea
    Jordysmash Thanks this.
  7. Jordysmash
    81
    71
    May 28, 2018
    this is the answer I’ve been looking for. Where do you get a good one if you don’t mind me asking?
  8. rbrtwbstr
    3,329
    7,589
    Jul 11, 2012
    Amazon. I just typed respirator in the search box and a bunch popped up
  9. Jordysmash
    81
    71
    May 28, 2018
    Awesome. Thanks a lot for your help
    rbrtwbstr Thanks this.
  10. wis bang
    3,348
    3,917
    Jan 12, 2011
    Levittown, PA
    Still amazed that I don't have lung problems. Over two summers me and the other 'college kid' got the chore of shoveling over every airslide that ripped. They were old [58, 59, 60] fruehaufs similar to airslide railroad cars.
    Instead of the traditional hoppers it resembled a double conical tanker with a central outlet. each side held an fabric covered [think firehose like] metal frame sealing a 1/2 length air chamber that was also the sloped floor of the half. There was a half high bulkhead across the center and when the fabric ripped, anything that didn't drop over the bulkhead needed to be shoveled out.
    We were given paper dust masks and big aluminum grain shovels. They kept the dome overhead open, closed the center and put a box fan blowing out on top of the far dome. We'd spend a whole morning shoveling. and the whole next day blowing grey/black stuff from our noses.
    OP amazon may be wonderful but there should be a safety supply store in your area.
    Go and have a respirator fitted and make sure the cartridges are the appropriate type [or stack of the right type] of filters. Don't skimp on replacements. Like all the adds we see for cleaning CPAP equipment, Keep it clean and if it is not on your face, it is put away to keep it clean.
    Inappropriate respiratory protection is more harmful than none as it makes one think they are making themselves safe when the equipment isn't sealed and the filters are not able to stop the fine particulate.
    Expect to spend for the correct protection; then feel the first handful of of dry cement and see how fine it is and know it is worth every penny
    not4hire Thanks this.
  11. RockinChair
    RockinChair Road Train Member
    4,918
    12,257
    Feb 19, 2012
    CC, TX
    The only time you should be exposed to dust is when you open the blowdown valve after you finish unloading. There should not be any dust during the loading process, assuming the loader put the spout into the hole correctly.
    And you can cut down on a lot of blowdown dust if you stop the blower with the blowdown valve closed and one of your hopper valves open, that way the tank ressure will blow into the silo.
    Also, putting a sock over the end of the pipe downstream of the blowdown valve will help trap lots of the dust.
    baha Thanks this.
