Drug/Alcohol Testing Consortium
Discussion in 'Ask An Owner Operator' started by JerseyShoreTrucker, Jul 21, 2016.
  1. JerseyShoreTrucker
    JerseyShoreTrucker Bobtail Member
    14
    Jul 15, 2016
    NJ
    Hello all-
    I am a new owner operator. I was notified by the FMCSA that I need to join a testing consortium. Can you tell me of any good companies out there that provide this service? Any help is appreciated. I want to sign up with a reputable company and some that I have researched online are quite costly.
    Thanks!!
    Dominick253 Thanks this.
  3. brian991219
    brian991219 Road Train Member
    2,921
    5,811
    Aug 10, 2013
    Lords Valley, PA
    For a single truck operator the easiest one to join is CCMI which is affiliated with OOIDA. Call their member services department and they can get you all set up, it will cost your annual membership of $45 plus $100 per driver per year which includes the tests except for post accident and return to duty (after a positive result).
    I use a smaller, local consortium that is much cheaper, but they only have a few offices so they are not a good fit for an OTR company. You can ask around at a smaller occupational medicine office, somewhere that already does DOT physcials and drug tests, they may have a local consortium that you can join for less money and hassle that is FMCSA compliant.
  4. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
  5. JerseyShoreTrucker
    14
    Jul 15, 2016
    NJ
    ok so we are already members of OOIDA. I checked out their program and it's $110 to join a one time fee. Then $125 per driver....... plus the membership fee.
  6. DUNE-T
    DUNE-T Road Train Member
    6,873
    16,584
    May 10, 2015
    Detroit, MI
    Nastc is $105 one time fee and then $35 for each test
    DSK333 and brian991219 Thank this.
  7. brian991219
    2,921
    5,811
    Aug 10, 2013
    Lords Valley, PA
    It has been a couple of years since I was with the OOIDA program, I guess the rates have gone up. There are other options out there, you just have to look for them, but still those rates are not that bad.
  8. spax
    spax Medium Load Member
    361
    364
    Aug 5, 2011
    United States
    I found a local outfit that does drug testing and they beat the pants off nastc and ooida's affiliate. It cost me $100 and that included my pre-employment and any random, everything I needed to be in compliance. So, just check around where you live and you'll find something more affordable.
  9. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    one thing about cmci is you don't pay for your random drug tests only requested drug test, like pre-hires or post accident, but if they call you for a random that is covered in your membership costs.
  10. osumike33
    osumike33 Light Load Member
    233
    66
    Jun 10, 2011
    Middletown, OH
    Isn't NASTC a do it yourself type of thing? CMCI is a lot simpler unless NASTC changed in the past couple years...
  11. DUNE-T
    6,873
    16,584
    May 10, 2015
    Detroit, MI
    You can do it yourself, or you can go to any Quest diagnostics. I think if you do it yourself there might be no $35 surcharge
