Driving with trailer air suspension dumped
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 04 LowMax, Aug 4, 2014.
  1. 04 LowMax
    04 LowMax Medium Load Member
    440
    250
    Feb 3, 2013
    Alberta
    Had an air bag blow on my lead trailer a few days ago. Fortunately it was in my own yard and I happened to be in the house. For anyone who's never heard one, it sounds like maybe a cannon shot. Ka-frickin-boom! Rattled the windows in the house! Got me to thinking, what if it happened with a load on driving on the highway? Could a guy dump the air on that axle group, drive 30 or 40 miles to unload without damaging anything? What do things ride on when they are dumped? It is common for super b drivers to pull ahead or back up with the trailers dumped where we unload at the terminals, but it is the driving like that which is my question? That would sure be a lot better option than spending hours on the shoulder until you get it changed out. Bolts are usually rusted requiring a torch or such to get them off.
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Not really a good idea. Good chance the tires will rub. Depending on what kind of suspension it is, you could destroy bushings and the bumper stops too. Big difference between pulling ahead slowly and driving down the road.
    I have plugged the air line to a blown bag and stuffed a block between the axle and frame using a ratchet binder to hold it in. This was just to get it back to our shop to fix.
    04 LowMax Thanks this.
  4. 04 LowMax
    440
    250
    Feb 3, 2013
    Alberta
    Yes, I thought of that. I did notice when I plugged the line off and turned around to get close to my shop that the other 5 bags were sitting at 90 psi with the increased load on the vs the 70 that they had been at before it blew. I imagine the block would take up the load? If not I'd be scared to run them at 90 in case more let go?
  5. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    Hendrickson supposedly has rubber bump stop inside of bag. I never saw inside of one.
    I know Freightliner bags don't and tractor frame has iron bump stop. Iron on iron - ouch!
  6. kalh7
    kalh7 Light Load Member
    186
    62
    Mar 28, 2007
    southern illinois
    And chance of getting a ticket, found out the hard way.
  7. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    my trailer has a Hendrickson suspension and it said in the manual that there are rubber bumpers inside the bags and you could safely drive with the suspension dumped as long as the distance was minimal and you kept the speeds down. I had to do it once when I blew an airbag out in the middle of nowhere and ended up driving about 80 miles with the suspension dumped until I could find a shop that had a replacement. There was no damage done.
    Cetane+, bergy and 04 LowMax Thank this.
  8. seabring
    seabring Road Train Member
    1,844
    1,882
    Apr 24, 2011
    I have kenworth 8 bag air suspension on the truck I drive in the oil fields. The way the saddles sit on that type of suspension allows small rocks to get in under the bag and I have bags pop regularly. So far this summer I have had 4 pop due to this problem. What I do is either crimp off the line to the bag or cut the lines and put in a coupler to by-pass the bag. With the 8 bag system it depends what bag has popped as to whether it can be crimped or has to be by-passed. I have worked a near full week with a by-passed bag and haven't had any problems so far. Keep in mind though that with the 8 bag system there are 2 air bags per axle end, so that lessens the effect of a blown bag on one axle quite a bit.
    A truck in the field with the usual 4 bag system blew out a bag last week and he was down until they got it repaired. The 8 bag is good in the sense that when a bag goes out the truck can keep working until the time is there to get it repaired.
