Driving with thermostat stuck open
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gunner76, Apr 18, 2016.
  1. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    Any harm in driving for awhile with the thermostat stuck open? I'm starting to think one of mine is stuck open since the engine will only run around 165-170 while empty in 50-60* temps. When loaded it will stay around 180*.
    Truck is a long hood 07 9900IX with a C15 ACERT. The engine has run cooler since I did some things(stuff we can't talk about anymore) to it a couple years ago but it seems like it has gotten worse. In the winter I have to block off the bottom third of the radiator to keep the engine above 170* but I don't remember having any issues when the temps got above 40* like I do now.
    Between the strong winds and rainy conditions things just haven't been favorable to tackle something like a thermostat replacement in my driveway so I was thinking of waiting until I get some nice weather.
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Not really. It might slobber a bit more. Any moisture in the crankcase doesn't get boiled out. That is the biggest problem, but this is a slow and long process so you should be ok.
    gunner76 Thanks this.
  4. gunner76
    500
    137
    Mar 11, 2010
    IA
    What temps does the engine need to run efficient? I always thought that it needed to be at least 150* to get a good burn of the fuel in the cylinder.
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    I never had a prob that I know of running cooler, but runner hotter than it should has caused me problems.
  6. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    You can wait it is not stuck open. If it was it would be running a lot cooler than that.. It would cool right off coming to a stop. It still needs to be replaced though it won't fix itself.
  7. blairandgretchen
    13,212
    70,208
    Dec 9, 2011
    South west Missouri
    No big deal short term.
    There's obviously a reason for thermostats, but running hot would be more of an immediate concern.
  8. Yves kanevil
    Yves kanevil Medium Load Member
    522
    465
    Jan 10, 2016
    Nighthawk
    Get a lazer temp gun and check actual engine temp your gauge could be off
  9. JAYRODPA
    JAYRODPA Light Load Member
    157
    109
    Dingmans Ferry pa
    if the stat is open it wont be a problem this time of the year. just replace it before the weather get cold again. otherwise you will have next to no heat. Truck will still run fine but will take longer to reach a good running temp. unless you have a truck that the computer controls everything. then the computer my create problems.
  10. SAR
    SAR Road Train Member
    2,756
    36,654
    Nov 26, 2011
    ND
    Gunner when I replaced my thermostats on my acert cause mine was not keeping warm, especially in the winter where I had to button up the front, what I found was the rubber seal on the thermostats itself was totally disintegrated allowing coolant to pass through all the time. My engine only had 400,000 miles on it at the time when I had to replace them. I'm willing to bet this is what's wrong with yours. It isn't to bad of a job to do just take your time. Good luck.
  11. Gear head
    Gear head Medium Load Member
    532
    91
    Apr 1, 2012
    Belair,md
    To check it start with cold engine. Start it up and let it warm up. If the upper hose gets warm or hot at all before 190 your thermostats are bad and need to be changed. The rad is supposed to be sealed off from engine untill thermostat opens. That upper pipe will be cool and soon as thermostat opens in 30sec you won't want to touch it anymore.
    gunner76 and blairandgretchen Thank this.
