driving with diff lock on??
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Mikesuburban1, Jun 29, 2022.
  1. Mikesuburban1
    Mikesuburban1 Bobtail Member
    44
    13
    Dec 30, 2016
    Rockland county ny
    noticed that my driver has been running with the diff lock in the on position while loaded running highway speeds. he says its better cause it helps with the weight when pulling a load. can someone please verify this? is this bad for the truck?
  3. buddyd157
    buddyd157 Road Train Member
    13,582
    34,896
    May 25, 2017
    under a shade tree
    i started driving at a time when it was VERBOTEN to drive with it locked, unless you needed to get off a slippery surface, or out of deep snow.
    i never drove with it locked, all my career.
    however, some will say that today's trucks, you CAN drive with them locked.
    however, i'd have to question the MPG's in doing so.
  4. God prefers Diesels
    4,198
    22,262
    Jun 26, 2020
    South Texas
    How so? Does that button activate a second engine?
    It's perfectly fine on straight roads. Once you start turning, it eats the tires, because they are trying to cover different distances while being locked together.
  5. AModelCat
    161,251
    Both axles drive anyways with it unlocked. All he's doing is chewing up tires for no reason.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,516
    6,570
    Aug 26, 2014
    And what happens if you have worn tires on one axle and new ones on the other? Some thing will explode soon.
  7. bigguns
    bigguns Road Train Member
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    @Mikesuburban1 Ask your driver where he gets his info. It might good a good idea to tell him to disregard that source.
  8. bavarian
    bavarian Heavy Load Member
    730
    785
    Feb 13, 2014
    Winnipeg
    The OP said diff lock not power divider. If the power divider is on all the time, it's not the best but not the end of the world.
    If the diff lock is on all the time, the end of the world is getting closer.
  9. bigguns
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    In my school the diff lock is the power divider. Locking rears is a whole ‘mother’ thing.
  10. bavarian
    730
    785
    Feb 13, 2014
    Winnipeg
    A diff lock connects left to right side.
    A power divider connects front and rear drive axles.
  11. bigguns
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    I don’t recall ever seeing the words ‘power divider’ on a switch plate on the dash.
