We have blown an airbag on the turnpike. We managed to get the airline sealed off but my question is, how bad is it to drive with the bag blown as it is? I read that it should be ok to get to the next repair shop. How fast is ok? What damage could be done? Anything helps! Thanks for any responses
Driving with blown airbag
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by CDL CPL, Apr 27, 2018.
The more loaded you are the more you should baby it. With one air bag not supporting the load, the other side gets more and uneven stress and could possibly break a spring. So just take it easy. Avoid pot holes, slow down for bumps and railway tracks. Take wider turns, stuff like that. For sure you can go to the next repair shop.
If I were you and I had a tight schedule I would drive till my hours were up and stop at a petro or TA. Or if you are close to delivery I would deliver first. Than get repair. If you are not loaded to the max you should not be stressing the suspension. As long as the leak is plugged I think you are legal.
CDL CPL Thanks this. -
If your loaded, no way I would risk going very far. Get to the nearest shop with the part asap. And change them both on that axle while your at it or at least get the other side to change when you get home. But I'm anal about matching suspension and brake parts on the same axle.
black_dog106, Expeditor, blairandgretchen and 5 others Thank this. -
We had to drive about 70 miles to get somewhere that actually had the part. $400 and 25 mins later we were back on the road. There was some rough riding there for a bit but for being on the turnpike doing almost 70 I was surprised how well she handled. Thanks to everyone who responded
You did not stipulate is this was on the trailer or the tractor. Were it me I would dump the air on the tractor and limp to the nearest available parts supplier. If on the trailer, and it does not have a dump valve, I would not want to venture far with the axle loaded on one side only.
SAR Thanks this. -
Driving with the suspension down on a truck for long distances can cause harmonic vibrations. We had a driver go 1000km with his air suspension down. Due to the excessive driveline angles and harmonic vibrations it exploded the syncro in his transmission.
Limping to the nearest repair facility is the best optionSuper_Trucker, black_dog106, flood and 3 others Thank this. -
As long as you have a plug to cap off the air line air bags aren't really too bad to do on the side of the road or in a parking lot somewhere. You've got a jack that way with your other air bags.
Oxbow Thanks this. -
SAR and Caterpillar Cowboy Thank this.
First airbag I ever changed my boss at the time couldn't believe that I went from blowing the bag to back up and running in an hour and half without a bottle jack and time tracking down an air bag included.
It seems like every time I see you guys you've got a pickup or two in tow. Some bad days I wish I had the luxury of help!Oxbow Thanks this.
