Driving a dump truck for a landscaping company
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Ddr1992 579, Jan 9, 2022.
  1. Ddr1992 579
    Ddr1992 579 Medium Load Member
    395
    100
    Sep 10, 2018
    Would a CDL class b work for driving a single axle dump truck that pulls a tandem axle equipment trailer? Less than 26k gvw dump truck that tows a trailer with a smaller piece of equipment would be less than CDL weight?
  3. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    Under 26,000 lb on the truck and under 10,000 pounds on the trailer you do not need a CDL at all.
    Don379 Thanks this.
  4. Kyle G.
    Kyle G. Road Train Member
    3,754
    19,604
    Jan 23, 2016
    Eastern Iowa
    Just remember, that 26k includes the trailer. So if truck and trailer combined weigh over 26k, you need a class B CDL. If the trailer alone weighs over 10k, you need a class A.
    Also remember, if you do end up testing with a dump truck and trailer to obtain your class A, you will still be restricted from operating a tractor trailer.
    Don379 Thanks this.
  5. Dino soar
    4,789
    26,858
    Dec 8, 2017
    Unless they have changed something this also is not correct.
    If you test with let's say a 50000 lb air brake dump truck and a 20000 lb air brake trailer if you tested for a class a combination and get a Class A license then you can drive whatever Class A vehicle and combination.
    Class A is what you are licensed and that is what you will be allowed to drive.
  6. Kyle G.
    3,754
    19,604
    Jan 23, 2016
    Eastern Iowa
    Correct, that would get you a class A cdl but you would have an “O” restriction, that’s why I say you wouldn’t be able to drive a tractor trailer.
    “An O restriction prohibits drivers from driving a Class A vehicle with a fifth wheel connection. An O restriction will be issued if a driver takes the skills test in a Class A vehicle that has a non-fifth wheel connection or pintle hook.”
    So if I understand this correctly, you could test in a dually pickup with a 5th wheel to clear the O restriction, but then you would have an air brake restriction. Could you test in a dually pickup to get the class A, then test in a dump truck to get the airbrakes? Now I’m getting in over my head here... LOL
    PS not trying to be argumentative here :D
    OldMainiac and Don379 Thank this.
  7. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    You will have a restriction. You want to drive semi truck, you need to take test in one. Those dayys were over the same day they came out with automatic restrictions. The new guidelines are as basic as this, you are to take test in the vehicle which you are dead set on driving. If you want the grand daddy of license , you are to take test in 18 wheeler with manual transmission.
    Badmon and Dino soar Thank this.
  8. Dino soar
    4,789
    26,858
    Dec 8, 2017
    That's interesting I never heard of an "o" restriction. But I got my license decades ago so I suppose it's possible.
    Yes a quick Google search shows that is indeed a restriction and there are other interesting restrictions I never knew about.
    What Are CDL Endorsements and Restrictions? - All Trucking
    And after February no one's going to get a license from their Uncle teaching them or their father. Everyone is going to have to attend some crazy accredited school.
    So much for making it easier for people to get into the industry.
    Badmon, Don379 and Kyle G. Thank this.
  9. Kyle G.
    3,754
    19,604
    Jan 23, 2016
    Eastern Iowa
    To be fair i didn't actually know it was called the O restriction either until I googled it this morning. I try to stay out of legal stuff because i normally end up more confused than i was when i went in.
  10. Lazer
    Lazer Road Train Member
    1,727
    2,715
    Jan 22, 2017
    There was no ‘O’ restriction when I got my class A. I did my road test in a KW T800 tandem axle dump truck pulling a tandem axle beaver tail trailer w/pintel hitch.
    Dino soar Thanks this.
  11. Does It Matter
    Does It Matter Bobtail Member
    5
    4
    Jan 20, 2022
    You have to go through a driving school regardless, so future-proof your effort and just get a class-A and avoid the headaches of a limited class-B. You'll be able to pull heavy equipment, drive rigs if needed, will look better than a class-B driver during hire in, and will have WAY more job opportunities in the future if you ever want to change pace.
