Driveshafts....all the same?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 6cuda6, Sep 13, 2021.
  1. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    Question....are all heavy truck driveshafts the same? So would a KW shaft be the same as a Volvo etc (i understand the length would be different).
    Trying to avoid a pricy custom driveshaft for a project, if i can get something from another brand that fits.
    Bean Jr. Thanks this.
  3. Big Road Skateboard
    5,684
    29,575
    May 2, 2021
    A used one with the same joints will be fine. Length is crucial though, so make sure slip yokes can fully extend and retract.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,417
    6,430
    Aug 26, 2014
    No they are not all the same. Common joint sizes are 1610 / 279, 1710 /280, 1760 / 407, 1810 / 281.
    Those are joints with all drive in caps. They come the same size in half round joints. Two caps drive in and two on the other yoke have bolt on straps.
    It is possible to buy a used longer bolt in cap joint shaft and shorten it. I have done it on a concrete floor and jack stands many times.
    Some of these newer Volvo shafts and such have you locked into big bucks.
    Can you send a few pic of what you are working on?
    black_dog106 and 6cuda6 Thank this.
  5. Rideandrepair
    17,198
    55,776
    Aug 8, 2015
    Driveshaft work isn’t all that expensive. New yoke while you’re at it if needed. Check them good. Sometimes they’re eggholed, even though ujoint is a tight fit. Look real good with ujoint installed. They can do whatever’s needed. Change ends, new tube, whole new driveshaft Might just be well worth getting a new one with new tube. Nice and straight.
    black_dog106, 6cuda6 and Goodysnap Thank this.
  6. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    Depends what you're trying to do. If you can find the same drive shaft in the scrapyard you may find the right length.
    The second cheapest is to get one that's longer and have them cut it down.
    The most expensive is to have the driveshaft shop make it for you.
    But I absolutely if it's something for a work truck buy new joints whatever yokes you need if you do, have a new carrier bearing put on it and make sure they balance the drive shaft
    6cuda6 and Rideandrepair Thank this.
  7. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    They are all different.
    A good driveshaft shop is worth its weight in gold. Bite the bullet.
    There are so many different varieties than the only commonality may be the interaxle shaft assy on a tandem drive set. There is still many different sizes and brands, too. Every OEM drive shaft is made to order based on driveline series and custom lengths, then spin balanced as an assembly.
    black_dog106, 6cuda6 and Rideandrepair Thank this.
  8. Dino soar
    4,789
    26,858
    Dec 8, 2017
    I have to say I have a shop it makes driveshafts for me and there's nothing cheap about it.
    But they know those Drive lines inside out and they have the right equipment.
    They have a jig to cut the tube perfectly straight. Then they have an automatic welder that welds it as another setup spins it.
    Then that same machine will spin it and balance it.
    Then they give you instructions to show what part is supposed to go where so that everything is together correctly to be in balance.
  9. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    The equipment is not cheap and neither is quality labor. There is also a ton of liabilty on driveshaft works due to its critcal nature. I'm not sure I would even want a cheap driveshaft shop. If you found one, there would most certainly be quality issues.
  10. skallagrime
    skallagrime Road Train Member
    3,836
    9,877
    Apr 10, 2012
    Indiana
    Cheap is relative, good drive shaft will last the life of the truck if not abused, they quoting you higher than 3k? Fine, might be a tad high, find a different shop, but under that, not really
  11. 6cuda6
    259
    176
    Oct 9, 2020
    Ok so as long as the yokes are the same any brand will do......if the yokes are different find a longer same brand/year as truck and have it shortened (with same yokes of course).....lastly, if no other option, have it made......sound about right?
    Rideandrepair and BoxCarKidd Thank this.
