Drivers that are Hams, What Freq. do you monitor?
Discussion in 'CB Radio Forum' started by russbrill, Sep 1, 2019.
  1. russbrill
    russbrill Medium Load Member
    325
    226
    Nov 10, 2017
    On the 2 meter band, the national calling frequency is 146.520 MHz (simplex), do you listen there?
  3. russbrill
    325
    226
    Nov 10, 2017
    FYI: the Larsen 2/70B is a Half Wave antenna (No Ground Plane needed) on 2 meters, and a 5/8 Wave Collinear on 440 MHz (six inch ground plane required).. The 2/70B is 34 inches tall, should work pretty good on most 18 wheelers...
    73,
    Russ
    KN6SD
  4. russbrill
    325
    226
    Nov 10, 2017
    Here's a list of Simplex Frequencies you can operate when communicating Truck-to-Truck:
    146.40-146.58 Simplex
    Simplex 146.400, 146.415, 146.430, 146.445, 146.460, 146.475, 146.490,
    146.505
    Note: The frequency 146.400 MHz is used in some areas as a repeater input.
    146.52 National Simplex Calling Frequency
    Simplex 146.535, 146.550, 146.565, 146.580, 146.595
    146.61-146.97 Repeater outputs
    147.00-147.39 Repeater outputs
    147.42-147.57 Simplex
    Simplex 147.420, 147.435, 147.450, 147.465, 147.480, 147.495, 147.510,
    147.525, 147.540, 147.555, 147.570
    Consult the Repeater Directory or ARRL website for additional information.
    73,
    Russ
    KN6SD
    Powder Joints and homeskillet Thank this.
  5. Neverready
    Neverready Medium Load Member
    405
    330
    Jul 24, 2014
    Pocomoke City, Md.
    I also recommend a repeater directory. I only run 2 meters in the work truck and program repeaters along my normal routes in addition to 146.520. Since the same frequencies are in use in different regions you still will hear repeaters you don't have programmed in if you don't use the receive tone squelch, then simply look up the transmit tone or your radio my do that for you,
  6. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    I use a Uniden SDS200 with GPS to automatically scan local repeaters as I drive. If I hear one active I can see both the frequency and CTCSS tone used and setup my ham rig if I wish to join in.
    I’m curious if there are any HF frequencies that drivers hang out on.
  7. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    I hang out on one of these: 7.010 or on SSB 14.195.
  8. Lowboy456
    Lowboy456 Light Load Member
    278
    127
    Mar 14, 2017
    Do you know if SSB works once a Radio has been converted from 10 to 11 meter?
    My Stryker 955 has been converted to 11 Meter but SSB mode low or high seems to just muffle the regular 40 CB channels.
  9. Night Stalker10
    Night Stalker10 Road Train Member
    1,668
    1,243
    Jun 26, 2017
    Once an import radio has been converted to 11 meters, it needs an alignment done.
  10. Lowboy456
    278
    127
    Mar 14, 2017
    Should the frequency's change once flipped into SSB? Mine stay at 27.185 for instance on upper and lower SB with channel 19 selected.
  11. Ubu
    1,252
    1,178
    Aug 25, 2012
    The frequency will not change when switching between AM, USB, and LSB. It shows the frequency of the carrier wave which is the same for all 3 modes for a given channel.
    Crude Truckin' Thanks this.
