Drive wheels locked
Discussion in 'Ask An Owner Operator' started by Batman13, Dec 9, 2020.
  1. Batman13
    Batman13 Light Load Member
    110
    45
    May 20, 2020
    All drive wheels lockd.. freightliner cascadia 2014..few turn ...then few dont...what could be cause??
  3. AKDoug
    AKDoug Medium Load Member
    323
    801
    Mar 21, 2018
    More details. Is it really cold out where you're at? Do you have air? Common' give us more to go on.
    feldsforever Thanks this.
  4. pavrom
    pavrom Road Train Member
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    Batman got his wheels locked ! Lol
    Sorry couldn't resist
  5. Spyro2112
    Spyro2112 Medium Load Member
    602
    412
    Mar 17, 2018
    Ouch gear box. Rearends out
  6. Batman13
    110
    45
    May 20, 2020
    Got air..n no not cold..a summer day
  7. jlafume
    jlafume Light Load Member
    241
    324
    Jan 6, 2011
    Victorville,Ca
    Maybe your slack adjusters, try backing them off
  8. REO6205
    REO6205 Road Train Member
    13,172
    60,483
    Feb 15, 2014
    California.
    OP, if you follow the above advice make sure your trailer brakes are set or if you're bobtail make sure the truck is in gear and/or the tires chocked. Also, if you're under the truck make sure the keys are in your pocket, not in the ignition.
  9. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    Are the brakes released?
    AModelCat Thanks this.
  10. AKDoug
    323
    801
    Mar 21, 2018
    OK they're not frozen.
    If you have air, have someone release the brakes on the tractor and see if all the brakes release. You can also do this solo, but you won't get to watch the slack adjusters move in and out. You can make a mark on the slack adjuster rods and see if they move when the brakes are released. Make sure you chock the tires.
    Next is mechanical. You say a few move, then don't. A better description would help. Sounds like you are getting power from the transmission to the rear axles. You could have a destroyed rear differential, or a simple snapped axle shaft. Pretty tough to tell through the keyboard if you don't do a better job describing exactly what is going on.
  11. AModelCat
    154,273
    Brakes worn out and they're stuck on the edge of camming over?
