Drive train power loss
Discussion in 'Trucks [ Eighteen Wheelers ]' started by morehp, Jan 23, 2013.
  1. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    I have recently been asked by a valued customer, what power will I loose through the drive train ?
    Any reasearch you do on the subject brings up 15 to 20 % loss.
    However the calculations will not add up because if you uprate the engine and re calculate the percentage you end up with a different result for power lost through the same driveline!
    Is there any one out there that has been lucky enough to test an engine on a engine Dyno and then again on a chassis Dyno ? And worked out the loss through a common transmission and diff configuration ?
    There are so many factors that will effect the results and I don't think any two identical setups will have the same loss.
    A base guide line maybe where the 15 to 20% came from.
    Look forward to the guys that have had alot of Dyno time's opinions!
  3. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    I worked at an engine dealership, and ran the wheel dyno, the specification is 82% of engine power will go to the ground on a normal unit.
    What I did was find an industrial area with a slight hill and a long run out, take the truck to 30 miles an hour to the top of the hill and take it out of gear and coast, remember where you got to after every repair test it, if it slows down early then you want to look for a dragging brakes, bad bearings what ever.
    Just a thought!
    morehp Thanks this.
  4. Koolk
    Koolk Bobtail Member
    42
    7
    May 19, 2011
    Richmond, BC
    We looked into this a few years ago when we were having problems with our cummins isx 550. Had our rep look into original factory dyno report and he said it was a 550hp not a 600 we thought was in the truck.
    Anyway cummins dyno at shop tested at 465hp on the ground. with 11R24.5 Bridgestone 726. 18spd with 4:10 ratio. Cummins said it was well within spec and more on the strong side! Hope this helps.
    morehp Thanks this.
  5. morehp
    699
    206
    Jun 18, 2012
    Sounds about right
    550 x .8 = 440 hp
    so you are on the winning side of calculations but if you uprate that engine the loss through the same driveline will change when calculating it.
  6. V8Lenny
    V8Lenny Road Train Member
    1,016
    130
    Aug 3, 2008
    Europe
    Constant losses These losses are neither dependent on the transmission's speed nor the load, i.e. they are constant. One example of elements causing constant losses is pre-loaded bearings. Due to the pre-loading, there is a constant friction force reacting to the rolling movement in the bearing. The pre-loading is in turn dependent on the temperature variations of the housing (gearbox, rear-axle, etc).
    Speed losses Speed losses increase with the transmission's speed and are, for example, caused by windage effect on rotating parts. These losses are greatly influenced by the type and temperature of media (oil-air mix) in which the parts rotate.
    Load losses As load increases so do the load losses. Load losses are mainly friction losses from the transfer of force from one gear to another. The greater force applied the greater the loss. If loaded in the normal direction: The load losses are approximately 1.0-1.5% / pair of gears for normal gears. The load losses for a pair of hypoid gears are approximately 2%
    Caterpillar NZ is using 10% loss with stock engine at about 600 hp, 18 sp and twinscrew.
