drive tire wear/ shimmying/ rear stabilizer bars
Discussion in 'International Forum' started by no love for a trucker, Nov 17, 2014.
  1. no love for a trucker
    no love for a trucker Light Load Member
    93
    26
    Jul 28, 2013
    Greensboro, North Carolina
    I have a 2009 International Prostar with ISX Cummins Engine. Does anyone know the side effects of bad bushing on the REAR STABILIZER BARS. I'm trying to figure out the cause to why I have as shimmying coming front the Left Rear Side of my truck. I have 2 tires the LEFT REAR INNER and the LEFT REAR OTHER TIRE are WEARING on the MOST INNER TREAD. I had a 3 AXLE ALIGNMENT DONE, SHOCKS CHANGED and AIR BAGS REPLACED. I was told to check my REAR STABILIZER BARS. I SEEN THE THE BUSHING were being worn towards the RIGHT SIDE.
  3. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    Shimmy's are caused by out of round or out of balance tires typically at 55 mph. Drive tires create a shake you generally feel in the seat, steer tires create a shimmy in the steering wheel. Usually worn spring and torque rod bushings do not create a sustained shimmy. If they are that bad to contribute to a shimmy or shake they are easy to see by eye.
    no love for a trucker Thanks this.
  4. no love for a trucker
    93
    26
    Jul 28, 2013
    Thanx Heavy D so what are the side effects of bad bushings on the stabilizer bar and could they be the cause for my left front and rear inner tire wearing on the most inner tire tread?
  5. Heavyd
    7,751
    6,184
    Feb 4, 2009
    If you mean the transverse torque arms, the bars that are perpendicular to the frame, very little actually. Those bars are only to keep the axle properly spaced side to side. The actual alignment is made by axle orientation front to rear. The side to side spacing is called tandem lateral offset. Worn bushings will contribute to wear, but not that significant. The axles would have more movement during turning due to side forces, but would generally ride centered once travelling straight ahead. Do you have any pictures of this tire wear?
  6. no love for a trucker
    93
    26
    Jul 28, 2013
    Yes I'm having trouble uploading my pics for some reason there not being excepted by trucker forum.
  7. Jerry12
    Jerry12 Heavy Load Member
    723
    282
    Sep 9, 2014
    ur pictures should be ok for uploading, following their formatting rules. ur a new user, just keep working at...i'd like to view them
  8. Jerry12
    723
    282
    Sep 9, 2014
    ??? pictures, im getting the impression you lost interest in your subject matter by not uploading pictures.
  9. no love for a trucker
    93
    26
    Jul 28, 2013
    I tried to upload pics I'm having issues for so reason.
  10. no love for a trucker
    93
    26
    Jul 28, 2013
    Hello Heavy D,
    It's been some time ihoe all is well, I've had those tires changed figured I'd get my money worth out of them as recommended to me but I'm still getting that shimmy/bouncy feel from the left rear end of my truck.
  11. 062
    062 Road Train Member
    6,144
    33,186
    Oct 20, 2013
    Have you had the wheel bearings checked for play?
