Draining Fuel Water Separator Necessary?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Sep 3, 2019.
  1. PE_T
    PE_T Road Train Member
    So I’ve heard we should be draining our fuel water separator daily, but is it really necessary? I honestly rarely do it. Yet I have never had any problems with it.
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Drain it. Water and espeically algae is your enemy in today's post 2007 fuels. Your dryer is a green house growing horrible things in plant life ready to consume your rig in ways you cannot imagine just yet.
    PE_T Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Every three months, never had an issue. Never seen more than a teaspoon of water in mine
    PE_T and x1Heavy Thank this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Daily is excessive. Most daily drivers get hot enough most moisture evaporates from the tanks. Most new rigs have a WIF sensor to warn the driver to drain the bowl and most engine manufacturers are mandating their use on OEM filtering units.
    For you guys into the new EPA stuff. In the not to distant future I am told that all Diesel fuel systems will be ventless and will have a mandated vapor containment system similar to automobiles. No on highway diesel trucks will be permitted to be vented to atmosphere. I would dare say manual water separator drains will also be on the chopping block.
  6. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    I cannot deal with non venting. Get into the death valley area at 120 and pavement is cooking at 150+... no thanks.
    Whats next cooling coils supported by seperate air conditioning compressor around each tank?
  7. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    The tanks will still be vented. Any vapors will have to be contained and filtered in a way that raw hydrocarbons cannot enter the atmosphere.
    spsauerland and x1Heavy Thank this.
  8. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    OMFG.
    What do I do with this box of.... gas pray tell? Does the shop people suck on it? //imaginary scenario...
    Goodysnap Thanks this.
  9. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    I appreciate the education, despite my feelings to this... this.. You think I swam in high sulfur fuel for years rolling down the road the way we did back then. Nothing harm done that I know of.
