I know there has been some discussion on this forum on what sequence to drain air tanks in or wether it even matters. Specifically though, I believe I understand that if you drain the wet tank first and you still have pressure in your primary and secondary tanks this is a way of checking if your one way check valves are working correctly. Am I right? Thanks in advance for any replies.
Draining Air Tanks in Sequence (Check Valves)
Discussion in 'Questions From New Drivers' started by Hairy Eyebrow, Feb 22, 2018.
Yes, completely draining the wet tank first will test the check valves in at least your primary tanks and usually your secondary’s.
The difference, some older trucks fill the primary tanks to 60-90 before filling the secondary’s. Most newer trucks ( at least what I’ve seen) fill primary and secondary at the same time. With the newer version you can test both check valves by draining the wet tank. As for the older system, I’m not for sure, the farmers that owned the ones I’ve seen, didn’t worry about the air system until the truck wouldn’t move.....passport220, blairandgretchen and Hairy Eyebrow Thank this. -
I’m about to learn something - seriously.Bob Dobalina and Lepton1 Thank this. -
Some newer trucks have a wet and secondary tank together, it looks like one tank, but there’s a drain on both sides. There is a divider in those tanks with an unserviceable check valve.Hairy Eyebrow, blairandgretchen, Bob Dobalina and 2 others Thank this. -
Here is a diagram google pulled up from this website: Basic Air Brake System Schematics
This shows the basic air system that the truck brakes are based off of. ABS,ATC, and RSS are just computer controls and valves added to this system. If the area in grey doesn’t catch the water, you get freeze up conditions in below 0 condtions. This can happen most commonly if your air dryer needs serviced or your compressor runs to much to maintain the air pressure leaks.
So... if your wet tank is dry, there shouldn’t be water in your primary and secondary’s, and if you have water in your system fix the air leaks and service your air dryer. I’ve found you get what you pay when buying cartridges for your cartridge style air dryers, in my case, if it doesn’t say WABCO on it, it doesn’t work. TRP and Alliance have both let me down....LexMak, blairandgretchen and passport220 Thank this. -
If both air systems fails, would you not be able to stop, or would you not be able to release the spring brakes and the truck would make a dangerous unwanted stop?
Thanks in advance. -
This diagram doesn’t show the trailer which is completely operated from the secondary system. Since most all trailers on the road have park brakes, they are designed to to start applying when the secondary air drops below 70-90 psi and the same thing applies, driver feels the drag and stops to investigate before the sudden application of the park brakes. Which makes the point, make sure all (both truck and trailer) brakes are adjusted properly so your park brakes will stop you!!!
If the entire system fails, you probably won’t be as worried about the sudden stop as the Toyota you probably just ran over!!!blairandgretchen Thanks this.
