drain the air tanks?
Discussion in 'Questions From New Drivers' started by zoekatya, May 9, 2014.
  1. zoekatya
    zoekatya Medium Load Member
    397
    99
    Mar 15, 2013
    Got a message on .the quellcomm saying to drain the air tanks twice a day? I thought you only drained them in the cold? Don't they drain on there own when I here the truck go 'psssss'? Where are the airtalks located? What do I do to drain them. Nobody ever showed me.
  3. Florida Playboy
    Florida Playboy Road Train Member
    4,102
    6,621
    Dec 19, 2012
    Florida
    The psss you hear is a purge if there is too much pressure in the system. You're supposed to drain them everyday but most drivers never do and there is no problem. Locate your air tanks and look for a a pin like thing to pull.
    zoekatya Thanks this.
  4. Pinner
    Pinner Medium Load Member
    410
    201
    Feb 14, 2010
    B.C.
    If your air dryer is working you never need to drain your tanks,ever.
    Moon_beam, Mooose and zoekatya Thank this.
  5. albert l
    albert l Road Train Member
    1,040
    1,505
    Feb 10, 2013
    On the Road
    Get under the truck and look for the tanks, you will see the ring and wire leading away from the bottom and follow them to where you see the handles then pull the handle to release the air. Get in the habit of draining the tanks daily with your pre trip.
    I know you have had a rough start to your trucking career but read as much as you can here at this website and look at youtube for trucker videos, a lot of people out there are trying to help us so take advantage of it !
    zoekatya and Tonythetruckerdude Thank this.
  6. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Assuming you can find the pull cables hidden here and there (if there even any still in place) pull them when you think about to see if there is any moisture leaving them. There probably won't be anything more than a "dry spit". That means your air dryer is working as intended. Today, air dryers rarely cease to work properly leaving moisture to accumulate in the tanks. And yes, winter is the worst time to have excessive moisture in the air system.
    Twice a day? No, just when you think about it once a week or so, (especialy if you have to dig around to reach the cables), or if you simply want to alleviate any concerns you may have.
    zoekatya and Rooivalkpilot Thank this.
  7. Tonythetruckerdude
    Tonythetruckerdude Crusty Deer Slayer
    2,905
    47,744
    Dec 8, 2012
    hunting...../ retired
    That works really good in climates that aren't too cold. but in the colder areas of the NE , the mid-west , the NW and Canada and Alaska , it doesn't hurt to drain them manually every time you stop....especially in the winter months and in temps that run in the single digits and below zero for prolonged periods. Maybe not absolutely necessary , but you know what "they say"..."an ounce of prevention keeps Johnnies truck from breaking down"
    Derailed, Davem3TF and zoekatya Thank this.
  8. Derailed
    Derailed Road Train Member
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    Very true, Surprising how much moisture still comes out of them even with an air dryer. Nothing like having to pull the air line off the compressor to dump a cap full of alcohol in the line on a sub zero morning when all you want to do is crawl back in bed.
  9. wsyrob
    wsyrob Trucker Forum STAFF Staff Member
    5,769
    5,463
    Sep 14, 2007
    Winston Salem
    Understand the reason you are doing it. If the air dryer stops working and its cold enough outside you can have moisture freeze in your air lines. That can cause loss of brakes. You should do it daily when its below freezing. Less often in the summer is ok but look for moisture coming out of the tanks when you do it as an indication that you air dryer needs a repair.
  10. Pinner
    410
    201
    Feb 14, 2010
    B.C.
    I live in the far north (mile 50 Alaska Highway) with below freezing temps for 6 months/year...I never drain my tanks, everything is good, I've only had an air dryer quit working once in 25 years.
    As said, nothing wrong with checking for water in the tanks before it gets cold.
    Tonythetruckerdude Thanks this.
  11. Tonythetruckerdude
    2,905
    47,744
    Dec 8, 2012
    Lucky guy....to each his own I guess....merely trying to give the OP some advice , going by my experiences...the way I look at it , getting into the habit of checking things out , and being a little proactive instead of having to be re-active after something breaks / freezes-up means that sooner than later you'll catch something that could have stranded you on the side of the road , or worse. Good inspection habits formed early on in a career are always , better than relying on a mechanical part lasting forever or trusting in "luck". Just my thoughts on it....
    Derailed Thanks this.
