I have a 2012 Kenworth with the paccar mx epa 2010 engine. Running derated now after egr delet pressure and dpf purge ### actuator warnings came on. I'm assuming the actuator isn't working right and that's causing the Delta pressure daily.
I haven't been able to find any information for the dpf purge air actuator for my engine, only some information for Cummins. I was hoping perhaps one of you nice folks here might have an exploded diagram of the after treatment system for this engine it might have had this problem also.
Thank you for reading
Dpf purge air actuator
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Trooper13, Mar 31, 2019.
The purge air actuator on a MX epa 10 functions in the same manner and is essentially the same part as on a Cummins. Driver side of the engine below the fuel filter is the solenoid valve with a 1/4" nylon air line feeding the valve.
Its job is to purge the fuel from the fuel supply line and the fuel doser when the dosing process for regen is completed.
Depending on your fault at hand you may have a voltage fault or a response or mechanical fault. If we know the fault we can better assist and lead you in the right direction. Without Davie this can be tough to handle......... Plus near impossible to clear the EGR derate which may already be active.HENRY!, Trooper13 and spsauerland Thank this. -
Thank you goodysnap!
Surely you know how paccar decided to be very proprietary and particular, i assumed it was different then the Cummins. I'll try to physically find it and see if there's an obvious problem i can fix. I ththoug it was under the passenger step with the dpf.
I'm a lowly lease driver and the Davies it cost prohibitive for now being the 4k for software and connector plus the 3 or 400 a month subscription to use it. If i can find the problem then hopefully the motor power Kenworth here in Casper will clear the derate for me as a courtesy, like you said the egr derate is extremely stubborn and doesn't like to clear even after all problems are resolved and the Davies is hooked up...Goodysnap Thanks this. -
Sure. I get it.
Replace the valve first. You can always ohm out the windings/coil in the solenoid as it should very low resistance. If open or resistance to ground or the body it is for sure bad. Next in line would be the doser and follows the same for measuring the coil. If that doesnt clear it up you likely have a wire rub and a green wire somewhere between the DCU and the part.
Keep in mind while these parts function the same, a Cummins part will not fit as the connectors are different for Paccar. Otherwise, they are exactly the same part. -
Sorry i forgot to post the follow up on this. This ended up being a leaking air line. There is a small airline that runs into a partner connector right by the fuel filter housing. It's a fairly tight run on my truck but somehow the airline was pulled and made crooked in the connector. I removed the parked connector and replaced with the crush cap connector. After stopping the leak the problem was resolved
iggybest, spsauerland and Goodysnap Thank this. -
Reason for edit: Wanted add an additional question -
iggybest, HENRY! and QUALITYTRUCK Thank this.
HENRY! Thanks this.
