DPF Cleaning
Discussion in 'Kenworth Forum' started by Artemstegailo, Mar 15, 2014.
  1. Artemstegailo
    Artemstegailo Bobtail Member
    7
    Sep 28, 2013
    Hello. I have Kenwoth T200 2010. When i bought this truck( 75k miles ago) dealer cleaner DPF for me. Now im cleaning it by myself, but i have check engine and dpf lights on sometime( often and often) and fuel economy becoming worth( maybe its just winter)
    So i have couple question
    1. Do i have to cleaning DPF by sending it out to Commins?
    2. my truck has 480k so do ihave to maybe change it?
    3. How much does it cost
    4. How often do i have to clean it in Cummins?
    5.does not clean DPF affect fuel economy?\
    Thank you!!!!
  3. Up74427ca
    Up74427ca Light Load Member
    145
    25
    Sep 1, 2012
    Little Saigon,ca
    Hi,Artemstegailo,it cost u around$450.You do it every 250,000 miles..
  4. Artemstegailo
    7
    Sep 28, 2013
    i cleaned it 75k ago and computer saying now i need to clean it again. maybe filter bad and i need to change it?
  5. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Is yours a four piece or three piece DPF? With the three-piece designs, you have to be especially diligent about checking the outlet for cracking, because they're prone to it... even if the cracks aren't visible, there'll often be a green residue.
    They make a pneumatic DPF cleaner... I'll try to get the manufacturer and part # for you tomorrow. It just requires a compressor and 1/4" line.
    Have you done your own DPFs yet? If not, I'd strongly recommend you go to Harbor Freight, and buy that $80 (and change) transmission jack they sell.... it will save you a lot of hassle, plus allow you to take off and install your DPF as a single unit, rather than having to do it all piece-by-piece.
  6. Artemstegailo
    7
    Sep 28, 2013
    i don't know how many pieces and I have not done it myself yet. I think i will do it in repair shop. i heard filter need to be cleaned every 250 000 miles, but made only 75 000
  7. WitchingHour
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    It may not be the filter itself... the problem could be the inlet (with a three piece system, the catalyst is in the inlet... in a four piece system, the catalyst is after the inlet), a sensor, the outlet... have you had someone hook up Insite and pull codes? Also, when was the last time you cleaned the dosing injector, and changed the insulator and gasket?
  8. Artemstegailo
    7
    Sep 28, 2013
    i didn't do anything to the filter at all. Who can check all than stuff? Cummins?
  9. WitchingHour
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Any service center with the Insite software can pull the codes and make an assessment based on those codes. The dosing injector is entirely separate from the DPF... the dosing injector is what injects diesel fuel into the exhaust stream before the DPF... cleaning it takes a wire brush, a 1/4" drive ratchet and either a 5/16" or 8mm socket, and a small pick... you undo the bolts, pull back the dosing injector... the gasket should fall off immediately... then you use your pick to rotate the insulator until it falls out... after that, you clean it out with your wire brush, replace the insulator and gasket, and bolt it all back together... on the Cummins engines for the year you specified, takes me about 15 - 20 minutes.. even less on the newer ISX models, where it's located facing out from the engine. Real PItA on the PACCAR MX engine, but not unbearable.
    So I'd say get the codes pulled, and make an assessment based on those.
    TopCatTrucking Thanks this.
  10. Artemstegailo
    7
    Sep 28, 2013
    ok, i will do it. Thank you for help
  11. cabwrecker
    cabwrecker The clutch wrecker
    1,626
    1,423
    Mar 23, 2012
    Don't try it yourself.
    Get it done by a reputable dealer- otherwise you're just wasting bunches of money.
    shanghi00 Thanks this.
