Double frame
Discussion in 'Peterbilt Forum' started by Z800xp, Dec 30, 2023.
  1. Z800xp
    Z800xp Bobtail Member
    20
    Feb 26, 2019
    How crucial is it to have a double frame pulling a 5lowboy lowboy trailer grossing 100,000 lbs once in a while? Will a single frame hold up? Just a tandem axle tractor and shorter than 240 wheel base.
  3. AModelCat
    154,481
    Depends. How thick and how tall is the rail?
  4. gt4jk
    gt4jk Light Load Member
    239
    107
    Apr 1, 2008
    It’s not so much the “doubling” the frame. It’s just more so of how much weight are you putting on the truck directly.
    also, how thick is the current frame?
    I think you’ll be just fine as long as you are not exceeding your axel/tire/suspension/drive line/transmission weight/torque ratings.
  5. zodiacflyer
    zodiacflyer Heavy Load Member
    945
    2,506
    Aug 25, 2014
    Do you mean lowboy, or RGN? On most of either of them, especially with a flip axle, most of the weight is on the trailer axles. I have pulled RGN trailers fairly successfully with a Cascadia. The tight turning circle is kind of a bonus on narrow lease roads. The only drawback is that very few Cascadias have locking diffs, which makes mud a bit of a challenge. It's not perfect, but rarely is anything perfect in trucking.
  6. 201
    201 Road Train Member
    12,052
    24,606
    Apr 16, 2014
    high plains colorado
    I've seen regular frames crack under normal circumstances, but I've never seen a double frame crack. Happened to my Western Star just pulling RR pigs. With the possibility of that much weight, it should be double at least under the 5th wheel. While it's true, most weight will be on the back, resonance will go to the front. I'd get a double frame.
  7. beastr123
    beastr123 Road Train Member
    2,803
    22,847
    Jan 2, 2014
    Moose Jaw SK CAN
    [QUOTE="[/QUOTE]
    This advice is concerning any load on todays tractors.
    Canadians regularly pull weights of 140,000# (8 axles) with standard tractors with tractors with a 240 or less wheelbase.
    As long as you are not exceeding rated weights on any axle on the tractor (13200#/14600# steers) (40,000#to 46,000# drives) and do not jerk the frame sideways under load you are perfectly safe.
    You should be safe to exceed the rated drive weights by 10% but do not exceed steer axle rating as that can overload the frame-rails between the drive suspension and the steering suspension.
    BobO1176 Thanks this.
  8. W923
    W923 Road Train Member
    1,299
    3,958
    Feb 28, 2022
    You will be fine unless you have a super light speced unit…100k isn’t really that much
  9. Animosus
    Animosus Heavy Load Member
    708
    2,774
    Dec 7, 2015
    SE Wyoming
    I wouldn't worry about it at 100k. I've done that with a single axle T300.
    Oxbow and beastr123 Thank this.
  10. RockinChair
    RockinChair Road Train Member
    4,928
    12,277
    Feb 19, 2012
    CC, TX
    A standard tractor in Canada has 8 axles?!?
  11. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Super b combination
