DOT Physical question ???
Discussion in 'Questions From New Drivers' started by dennisroc, Jul 14, 2014.
  1. dennisroc
    dennisroc Road Train Member
    1,753
    1,257
    Oct 9, 2013
    Anjung-Ri, South Korea
    I am type 2 Diabetic and wonder what all is involved on the physical.
    I can control my diabetes with pills but chose to take insulin as it seemed to work better for me.
    I will stop using insulin very soon and will tell the doctor I am just using pills. Physical will probably be in about 6 months.
    Does the doctor take blood and check for diabetes or check your sugar just that day with a glucose meter and blood from your finger tip.
    If anyone has info on this , I sure would appreciate it.
  3. MsJamie
    MsJamie Road Train Member
    Every DOT physical I've done (and that's quite a few over the last 20 years) was a urine dip for sugar.
    As I'm sure you know, insulin use is prohibited while driving a CMV. Get your sugar under control with diet, pills, and exercise, and you'll be fine.
    dennisroc Thanks this.
  4. High Desert Dweller
    High Desert Dweller Medium Load Member
    431
    389
    Jan 29, 2009
    You pee in a cup, they check the specific gravity.
  5. dennisroc
    1,753
    1,257
    Oct 9, 2013
    Thanks for the info , do you know if a urine dip shows the reading for just that day ?
    I know an A1C test is an average for the last 3 months but not sure about the urine dip ?
    Yeah I know I can't use insulin as a driver and that is why I am going back on pills. I had better control using Lantus insulin and pills but I have lost weight and am off blood pressure meds and am sure no problem going back on pills.
  6. MsJamie
    Urine only covers the last several hours. It's not very specific; it can't tell the difference between 110 and 130.
    The urine dip is only a diagnostic tool to detect very high sugar levels, such as those you have when diabetes is not controlled. If the dip flags high sugar, most places will do a blood test.
    My average glucose is around 130; a bit high for "normal", but I easily pass the urine dip.
  7. dennisroc
    1,753
    1,257
    Oct 9, 2013
    I can get my sugar to read pretty low with taking pills and fasting. What if your sugar is too high at testing , do you not pass the physical. Will they give you another chance to come back and test again.
    Also wondered about high blood pressure. I am off meds now but what if your BP is too high , I will check it before I go but was curious as to what happens and what the limit was.
  8. TomOfTx
    TomOfTx Road Train Member
    1,190
    1,406
    Jul 13, 2013
    Friendswood, TX
    Glucose in the urine by it self will not cause you to fail the DOT physical. Many prescription drugs and vitamins taken in the hours prior to you giving urine to the doctor for testing can show glucose in the urine. This happened to me once and was surprised to see glucose in my urine. I bought the test strips and tested at home for several days. It was narrowed down to urinating for the first time following me taking a few cholesterol medications, but showed negative all other times of the day. Now, I make sure to take these medications many hours prior to a physical so my urine does not shows traces of glucose.
    Also, there are 2 newer diabetes medications on the market, Farxiga and Invokana. They both are aimed at lowering a person's A1C blood sugar. They both work to lower glucose by removing it through the urine. If you are taking either of these medications, it will show high levels of glucose in the urine.
    OP, if you can get by with taking a pill and/or adjusting your diet, that is preferred. If you take insulin injections, you will have a hard time being cleared to drive. The doctor who performs your DOT physical will not draw any blood to check your current blood sugar.
  9. dennisroc
    1,753
    1,257
    Oct 9, 2013
    Yes I am planning to stop insulin long before I go for my physical. I hope to move back to America from South Korea in 6 months to a yr and start CDL school and start driving.
  10. rda2580
    rda2580 Heavy Load Member
    749
    5,484
    Feb 22, 2012
    Lower Michigan
    Not sure what your diet is over their Dennis, but the father in law is diabetic and once we got him off of gluten his blood sugar numbers drastically improved. So if possible get off of wheat, white rice and any other processed foods you can eliminate. Veggies need to be your friend forever and ever amen!
