Dot physical 2nd opinion
Discussion in 'Questions From New Drivers' started by EnleMane, Nov 4, 2022.
  1. EnleMane
    EnleMane Bobtail Member
    7
    5
    Nov 4, 2022
    Okay, so 3 years ago I went to concentra to start my trucking career. The examiner gave me a 3 month card and told me I had to do a sleep study. Soley on bmi(39 at the time) and neck size. I had leave that behind because the sleep study was way too expensive and I believe I truley didn't need it. So I got my regular construction job back.
    Now forward to the present day, I just discovered the whole 2nd opinion thing from a truck driver I met on a construction site. So can I just go get a new dot physical? I have nothing to hide from my first physical. Do I need the old paper work to give the new examiner? I want to set up an appointment from a week or 2 from now.
    Thank you all
  3. zaroba
    zaroba Heavy Load Member
    840
    1,269
    Aug 28, 2012
    South East PA
    Well, the 3 month medical card issued 3 years ago is long expired so you need a new one regardless. I'd just pretend that 3 month exam never happened.
    But yes, if you go to a doctor and they deny you or want you to do a test, there's no rule against walking out and going to a different doctor to try again. Even if that first doctor gave you a 3 month card, another might give you a 2 year card. Just trash the 3 month one and submit the 2 year one to your DMV.
    Try finding an independent doctors office or a local chiropractor, far less likely to nitpick or scam you with a sleep study. Don't go to a corporation or large chain place like concerta.
  4. rjlopez3332
    rjlopez3332 Bobtail Member
    Sep 24, 2020
    Exactly what Zaroba said! Concerta is by the book. They'd rather go by a body scale sheet than actually have you perform a couple of physical activities, like touch your toes and squat. Your chances for getting a 1-2 year med card skyrocket if you go to local doctor.
    Good Luck Bud!
  5. silverspur
    silverspur Road Train Member
    1,516
    6,796
    Sep 26, 2012
    What state are you in?
  6. EnleMane
    7
    5
    Nov 4, 2022
    Florida, will this change things?
  7. Chinatown
    Chinatown Road Train Member
    73,297
    164,766
    Aug 28, 2011
    Henderson, NV & Orient
    No.
    Avoid Concentra.
    DOT Exam Locations - Find DOT and CDL Exam Locations …
    DOT Exam Locations provides a centralized directory of certified DOT and CDL medical exam locations across the country.
    Never know when you'll run into a power hungry person that's authorized to do physicals.
    CVS Pharmacy also does them.
    Some chiropractors are on the authorized list. Some are OK and a few are hardcore by the book.
  8. Moose1958
    Moose1958 Road Train Member
    15,094
    33,184
    Dec 17, 2010
    Williesburg, Virignia
    Your question actually has no easy answer. I am going to draw your attention to the bottom of the current MCSA-5875 where the ME certifies you. Keep this in mind. That certification while 3 years old is the last one in the FMCSA ME database. A ME made a determination you needed a sleep study and placed such a certification in the FEDERAL RECORDS under your ID. I also suspect you self certified so you could keep the CDL for these 2 years and 9 months after the physical expired. I HIGHLY recommend you tell any new examiners about that 3 months card. You do not want to have the FMCSA tossing your new physical for doctor shopping. YES, even 3 years after the physical expired the records are still in the FMCSA database.
    This BS is why drivers are having problems getting physicals. The problem is once a Concentra gets their claws into you this can get a bit "sticky". I know what I am saying is peeving you off, but I am attempting to save you a lot of time and problems later. @brian991219 what say you?
  9. NewWorldTrucker
    NewWorldTrucker Light Load Member
    107
    142
    Nov 2, 2022
    FMCSA National Registry
    With the new rules you can only get certified by approved examiners on this list. Make sure whomever you choose is on this list.
    Then use this list to find approved schools to attend. Most will offer scholarships.
    Training Provider Registry
  10. brian991219
    brian991219 Road Train Member
    2,924
    5,816
    Aug 10, 2013
    Lords Valley, PA
    Thanks M,
    You are correct, his last medical certification is the one that matters. So, to get a new one today, even 3 years later, he would have to answer all the questions honestly including that he has had a medical certificate for less than 2 years. If, when the evals are done and the long form was filled out the same as the previous one (except for anything that has changed in the last 3 years) the new certified medical examiner finds he does not require a sleep study the certification is valid and will hold up to FMCSA scrutiny.
    Getting a second opinion is not a bad idea, the only requirement FMCSA has is to compare apples to apples, meaning answer the long form questions exactly the same for both examiners.
    BennysPennys and Dino soar Thank this.
  11. tscottme
    tscottme Road Train Member
    Other drivers with issues have reported that going to a chiropractor that does DOT exams is usually more driver friendly. The SYSTEM is now better able to track DOT medical exams than in the past. The SYSTEM is aware that some drivers "Doctor Shop" or keeping going to different medical offices until they get one that will pass them. The Doctor, nurse, etc that completes a DOT exam is supposed to report that exam to the state even if you don't. So you are safest to find the doctor, or whatever, and THOROUGHLY investigate to learn if your issue is one that can pass THAT doctor's process BEFORE you get another 3month card. Also, remember the DOT medical exam doctor, nurse, whatever is NOT your partner in health and a possible best friend or psychological counselor. For the most part, they are only going to know the answers to the questions on the medical form from the answers you write on that form. There is no small-talk in a doctors's office from anyone "behind the counter". I think it is safer if you view those people as the people that can take away your income if they find something wrong with your health or you give them the wrong answer to certain questions. BTW, there are at-home sleep study programs that are not expensive. Many of the people I've know that have a sleep study and then use some device, like a CPAP, report it was one of the best things they ever did. Their sleep quality is so much better than before. Nobody wants to take a sleep study or use a mask to sleep, but it could be a great improvement.
    BennysPennys Thanks this.
