Doran TPMS
Discussion in 'Prime' started by Locrius, Dec 21, 2013.
  1. Locrius
    Locrius Bobtail Member
    27
    20
    Jul 11, 2013
    DeWitt, Iowa
    My TPMS has a red light and shows "lost signal". The fix from road assist was to enter the number from the tire sensor, but that did not work. It is showing lost signal for all my tires. Anyone have any ideas how I can fix it?
  3. olphart
    olphart Medium Load Member
    301
    146
    Feb 15, 2009
    Minden,LA
    That's gonna be an antenna issue. Make sure the wire is screwed in good and if you can find where they mounted the antenna, check that end out too. It's usually under the truck somewhere.
  4. Chucktaylor
    Chucktaylor Road Train Member
    1,065
    640
    Sep 26, 2012
    When it's extremely cold I get a signal loss from the left rear sensor. It's the one furthest from the antenna.
    The he problem clears itself within 10-15 minutes on my truck
  5. jk72180
    jk72180 Light Load Member
    246
    66
    Jul 10, 2013
    Cedar Hill MO
    I wish I could see mine. For some reason it was taken off the dash (the holes are still where it used to be) and placed it on the bunk behind the curtain on the other side of the inverter.
  6. PChase
    PChase Road Train Member
    1,334
    613
    Sep 16, 2012
    Show Me State
    Somehow that made a part from "hitchhikers guide to the galaxy" pop into my head. The notes for the bypass was in the local planning office, in a locked filing cabinet, stuffed in the corner of a disused lavatory with a sign on the door that said "beware of the leopard".
    Locrius and jk72180 Thank this.
  7. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    Who is using this Doran TPMS ? is it worth to have it ? I need reviews please.
