Door Latch Replacement
Discussion in 'Peterbilt Forum' started by HalpinUout, Jan 25, 2018.
  1. HalpinUout
    HalpinUout Road Train Member
    7,074
    18,159
    Oct 2, 2011
    Anyone ever replace the door latch on your truck door? Mine keep popping open while going down the road so picking one up from Peterbilt tomorrow to put on my 587. I've never taken apart a door or anything like that, it does have power everything (window/locks/mirror) Just wondering is it relatively easy once I get the panel off or is it a pain in the rear? Any do's or dont's that any of you that have replaced one before shall recommend? Any tips? Thanks.
    Shock Therapy Thanks this.
  3. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    It should be simple, just disconnect the lock rod clips and unbolt or unscrew the mounting hardware from the door shell, install the new one and reconnect the lock rods.
    I would have a good pair of long nose needle nose pliers and some different length flat bladed screwdrivers because reconnecting the lock rods can be a pain.
    HalpinUout Thanks this.
  4. Imadebail
    Imadebail Bobtail Member
    27
    57
    Nov 7, 2017
    Oregon
    careful not to break the plastic retainers on lock and door release rods. (they snap sideways off of rods to release/install, hard to explain)
  5. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Look at the striker that bolts on the door jam it gets worn and will let your door fly open at the worst times?
    HalpinUout and blairandgretchen Thank this.
  6. Imadebail
    27
    57
    Nov 7, 2017
    Oregon
    Yea good thought. Could it just need lubed and adjusted? Come to think i have only changed door latches that are broken.
    Jazz1 Thanks this.
  7. HalpinUout
    7,074
    18,159
    Oct 2, 2011
    The door doesn't fly open, its just becomes "unlatched" but still locked.
    Shock Therapy and 4mer trucker Thank this.
  8. baha
    4,137
    2,835
    Jul 25, 2013
    ga
    Ck for slots worn in to part thats bolted to door frame if thats it just have the torx socket to replace it ?
  9. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    That's my thought. Nader bolt needs adjusted. Usually Torx head bolt and it will be tight!
    Imadebail Thanks this.
