Does the Air Conditioning have to work to take the CDL Skills Test?
Discussion in 'Questions From New Drivers' started by NY2001, May 12, 2022.
  1. NY2001
    NY2001 Light Load Member
    65
    56
    Sep 22, 2019
    Apparently, I was close to passing my Pre-Trip today until my examiner complained the truck was hot, so she is not willing to test me without a functioning AC and told me I had to reschedule. As I finished inspecting the outside of my truck, I told her during the in-cab, the AC was not working but she said she can't work when it's too hot (the inside of the truck was hot but I don't think the manual states it has to be working). She said I need to re-schedule and try again so I failed.
    Can someone explain if the AC has to be working or if she was wrong here?
  3. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    as far as i know, if it's on the truck, or in the truck, it has to be working.
    never heard of cancelling a test here in my area, (i taught for 3 states at a CDL school) but, some testers run the rules and no way to complain about them.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    You know this is wrong because we've talked about it in the past. Go read part 393 and is the a/c listed? (hint, it's not) it's not required to work on the federal level.
    That said, it could be a state thing (doubtful) of most likely it sounds like the tester didn't want to work in an oven.
  5. TheLoadOut
    TheLoadOut Road Train Member
    2,138
    10,048
    Nov 6, 2019
    Sounds like the tester just throwing their weight around.
  6. rbrtwbstr
    rbrtwbstr Road Train Member
    3,329
    7,589
    Jul 11, 2012
    in the bush somewhere
    Tester probably had some medical reason for this.
    I know in PA the state seems to like hiring those with disabilities. Could be that the tester had some kind of medical condition that makes the heat dangerous for her.
    Now whether the A/C has to work? No. It doesn't HAVE to work.
    Did they actually fail you for this? Or just have you reschedule?
    D.Tibbitt Thanks this.
  7. NY2001
    65
    56
    Sep 22, 2019
    Re-schedule, but said I would have to do the entire Pre-Trip again.
  8. rbrtwbstr
    3,329
    7,589
    Jul 11, 2012
    That makes better sense. When I did my CDL test in 2001, I did my pretrip, we went on the road and I scraped a curb and failed the road test.
    I went back a week later and still had to go through the pretrip portion
  9. ZVar
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    And if you go back in that vehicle without a/c, make sure all the windows are open on the way to the testing site. Make sure it's at least no hotter inside than outside. Heck, I might take it to a carwash and spray it with water to cool the metal off a bit. Don't know if it will help, but it won't hurt.
  10. Lazer
    Lazer Road Train Member
    1,728
    2,725
    Jan 22, 2017
    The tester may site it as an OSHA failure, not a DOT item. Now, you can’t expect our civil servants, or their contractors to be uncomfortable do you?
  11. SmallPackage
    5,273
    16,442
    Dec 20, 2019
    Marion Texas
    Just get it working and point all the vents towards the passenger seat. Make it so it gets so dang cold in there you have to wear a snowmobile suit to ride in it.
    It’s a bus put a roof unit or an rv style floor or window unit right there at the seat, crank it to 11 on cold and rip the knob off.
