Does schneider use camera's in the cab??
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by LimpyLegs, Jan 7, 2021.
  1. LimpyLegs
    LimpyLegs Medium Load Member
    341
    171
    Aug 26, 2008
    Midland,VA
    I just recently helped a schneider driver out of a bit of a rough spot...backed the truck up for him.
    I never realized it but I was thinking afterward I could have gotten him into trouble doing that if they look at camera's inside the cab on a frequent basis.
  3. gräkken
    gräkken Light Load Member
    69
    140
    Dec 13, 2020
    This site needs a list of companies with driver-facing cameras so we know which ones to avoid.
    jaws2003 and GreenPete359 Thank this.
  4. Voyager1968
    Voyager1968 Road Train Member
    2,372
    2,887
    Sep 11, 2008
    It has one, but the info is pretty old, and the few updates to it are scattered about. If one of the admins would pin a post with the most up to date info and add to it as drivers report new companies, it would be most helpful.
  5. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
  6. gentleroger
    gentleroger Road Train Member
    7,199
    19,318
    Jun 1, 2010
    Schneider doesn't have driver facing cameras.
    Even if it did, the camera system isn't activated unless a "critical event" is recorded. If a driver pops a "critical event" while backing, s#!+ akin to the 4 horsemen is going down.
  7. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
  8. nredfor88
    nredfor88 Road Train Member
    1,801
    6,096
    Sep 26, 2019
    USA
    The driver for a Salt Lake outfit that pulled in next to me at my last shipper probably tripped an event backing. He had the trailer bouncing off the ground like a basket ball when attempting to slide the tandem. Then he proceeded to slam the sliding mechanism stop hard enough that I'm surprised it didn't shatter right there. As a grand finally, he hit the dock bumper good enough to send him forward again a good ways.
    firemedic2816 Thanks this.
