Does no oil on dipstick mean no oil in engine?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by RoadRunner23, Mar 28, 2025.
  1. RoadRunner23
    RoadRunner23 Bobtail Member
    9
    11
    Mar 5, 2025
    Theoretically, If the dipstick shows no oil on it, does it mean the engine has no oil in it? What if the dipstick is not bone dry but gets little spots of oil on it when checking?
    After that let’s say you go for an oil change, plenty of oil is still in the oil pan as can be seen when draining, but not filled enough that it shows on the dipstick, will it have damaged the engine?
    What does overfilling oil do to an engine?
    Asking out of curiosity.
    Star Rider, D.Tibbitt and austinmike Thank this.
  3. AModelCat
    158,827
    Dipsticks don't normally touch the bottom of the pan. They might only show the top 2 or 3 gallons. As long as the oil pickup is covered there should be oil getting pumped through the system.
    Still, keep it between add and full. Manufacturer put those markings there for a reason.
    Bean Jr., Tb0n3, LoneRanger and 8 others Thank this.
  4. Big Road Skateboard
    6,162
    33,776
    May 2, 2021
  5. Concorde
    Concorde Road Train Member
    4,711
    16,830
    Jun 29, 2016
    West Melbourne Florida
    Lol, that was my first thought..too funny.
    His 1st question is basically a FAFO response.
    2nd question there’s a ton of information on this with even the simplest web search.
  6. rbrtwbstr
    rbrtwbstr Road Train Member
    3,374
    7,785
    Jul 11, 2012
    in the bush somewhere
    Steps for checking engine oil
    1. Open hood. If unsure how, return your flip flops to wally world- you're not worthy.
    2a. Locate dipstick- usually has a T-shaped handle attached. Typically located close to frame rail. If found, proceed to step 3. If not located go to step 2b.
    2b. If unable to locate, just look for codriver. You've found the dipstick. Once found, smack upside the head and revert to step 1, and begin the steps again, making codriver perform the steps.
    Step 3. Remove dipstick. If oil is found to be below full mark, turn dipstick upside down until oil runs to full mark. Proceed to close hood and drive truck. If no oil is present, proceed to step 4.
    Step 4. Close hood, using codriver's head as a buffer to prevent codriver from multiplying. Begin driving truck. Call Muhammad and pray to Allah.
    Oxbow, LoneRanger, Hammer166 and 7 others Thank this.
  7. Concorde
    4,711
    16,830
    Jun 29, 2016
    Step 3…I’ve done that before hahaha
    Oxbow, Feedman and D.Tibbitt Thank this.
  8. Star Rider
    Star Rider Road Train Member
    1,496
    12,296
    Sep 23, 2019
    Only thing I found with a T handle says 710, what do I do now?
    Bean Jr., Oxbow, IH Truck Guy and 5 others Thank this.
  9. FLHT
    FLHT Road Train Member
    1,381
    2,404
    Aug 2, 2014
    If its a fleet truck chances are its the wrong dip stick ..
  10. Sons Hero
    Sons Hero Road Train Member
    2,289
    22,598
    Jan 8, 2021
    Indiana
    what color is the truck? See if you can pull it out, if so, taste test never fails! If it’s not vanilla, you likely have a blown head gasket
  11. rbrtwbstr
    3,374
    7,785
    Jul 11, 2012
    I borrowed my Dad's pickup one day, he told me I had to check the oil first. So I did step 3.
    You know, there were ### beatings as a child that you remember. But I doubt too many people have ### beatings as adults to remember. But I do
