Does my Wabco dryer need a purge tank?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Wesco, Mar 16, 2012.
  1. Wesco
    Wesco Bobtail Member
    29
    May 19, 2011
    Not the most life or death question I know, but if you've got a second here it is:
    When I got my truck the air system had been "gone through" (and bastardized a little) and there was a little 1 or 2 gallon tank bolted up next to the air dryer (Meritor Wabco) but it was 1/2 full of water and already d/c'd so I yanked it off & chucked it in the corner of the shop.
    Now that I'm getting around to servicing the dryer I've discovered that it was probably a "purge tank" and it just filled up 'cause the filter was bad. Dryer seems to be working fine w/o it, any reason I should hook it back up?
    Thanks!
    FWIW, the truck is a '99 Oshkosh FF-2146 w/Cummins ISM
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I cant be sure you name all parts right, but purge tank, is really dryer regeneration tank. It is small, about a gallon, and when compressor cuts off air from this tank runs in reverce direction from air dryer cartridge, blowing out oil/water emulsion throught the regeneration passage (down to ground).
    Wesco Thanks this.
  4. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    That little tank would be an aid to your dryer and improve the dryers performance by:
    Collecting water and oil that would normally be cycled through the dryer.
    Providing air volume at the dryer for the purge cycle.
    The addition of the tank would extend dryer service intervals and help prevent dryer freeze up in winter weather.
    The tank should be drained daily for maximum efficiency.
    The tank isn't necessary, but a good addition if regularly tended to.
    Wesco Thanks this.
  5. Wesco
    29
    May 19, 2011
    OK, thanks for the responses; when I get a minute I'll bolt it back on.
    Y'all are great!
    -Wesco
  6. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Modern air dryers drain purge tank automaticly every time compressor cuts off. simple idea but saves cartridge.
    New electronic air dryers are smart and calculate cartrige use. but EAPUs are expencive toys and now they are rare
