Dock locks, damage and suspension.
Discussion in 'Questions From New Drivers' started by Chebbydriver7195, Apr 4, 2019.
  1. Chebbydriver7195
    Chebbydriver7195 Light Load Member
    113
    121
    Feb 24, 2019
    If I dump the air suspension on the truck to tilt rear of trailer up will it hurt the truck?it was the only way for me to actually get against the dock.
  3. Snow Monster
    Snow Monster Medium Load Member
    543
    1,296
    Feb 9, 2019
    What you could do is drop the air on the tractor, then crank down your landing gear before you start loading.
    That way the suspension won't be damaged and you won't feel as much jarring and vibration in the truck as the forklift runs in and out of the trailer.
    WesternPlains and Finfn1372 Thank this.
  4. WesternPlains
    6,274
    51,420
    Sep 1, 2017
    I like that idea of landing gear down. :biggrin_25514:
    When suspension lowered. That kingpin plate is almost touching the tires. Not a good position to be doing much at all.
  5. Ridgeline
    22,103
    113,211
    Why do you have to be "against" the dock? You should have some gap between the trailer and the dock.
  6. tinytim
    tinytim Road Train Member
    5,143
    18,067
    Oct 29, 2007
    Northern Ontario
    Is this dock on an incline or something? You shouldn't usually have to 'tilt' the trailer. If you're on an uneven slope the position of the tandems can affect the height at the rear of the trailer.
    x1Heavy Thanks this.
  7. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    No you won't hurt it. There are plenty of trailers with air systems that automatically dump the air bags.
  8. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    I was getting ready to say... Most docks have the tandems at the 48 foot mark or all the way back. I rarely disconnect unless ordered to by the stiff suits...
  9. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    the road less travelled
    Some plates won't reach far enough, I know what the op was saying, and we have a place we have to either do that, or hit the dock lock hard enough to push it down. The plate won't reach without the trailer being close enough to be locked in.
  10. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Hes talking about dropping the tractor air bags...
  11. Chebbydriver7195
    113
    121
    Feb 24, 2019
    Well the truck is fine. This place usually uses one of those metal portable docks but it was broken. The road slopes down toward the dock really bad. If I had a shorter trailer it would be fine.
    I didnt think about using the landing gear to take some pressure off truck. Like I said tho even with suspension dropped(on just the truck) I had to lock the diff and back up to the point the rear trailer tires were lifted significantly. Almost off the ground
