Dock incident, was told good to go but a guy was still in trailer
Discussion in 'Experienced Truckers' Advice' started by Iemontel, Oct 20, 2022.
  1. Iemontel
    Iemontel Light Load Member
    127
    71
    Jan 10, 2020
    I have a concern , today I was being unloaded in Arizona , at a small receiver , so dock didn’t have no green light or red light set up, or any precautions. The thing is after being unloaded and empty the worker gave me the paper work and said I was good to go , so I simply said thank you have a good day , so I get into my truck and start pulling foward slowing to close my door , when I hear a loud noise coming from back of the trailer , happens to be the the same guy who told me I was ready go was inside the trailer when I was pulling foward. Thankfully he did not get hurt , but I’m just worried that I’ll get into some type of problem now . Any opinions or comments would help ease my mind , before leaving I spoke with the boss to clear everything up and he simply said it’s my fault but sense the worker was ok everything was good . Do they need make a report or should I be fine ?
  3. Chinatown
    Chinatown Road Train Member
    73,250
    164,501
    Aug 28, 2011
    Henderson, NV & Orient
    You learned a good lesson. Even if you're told you can leave, still check the trailer before pulling away.
    I've seen a truck pull away from a dock then pull over to close the doors and there's a forklift inside with the driver.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Your boss is wrong. It's not your fault at all. If a report hasn't already been made you will get into no trouble, the worst that will happen is you simply will be banned from that specific location again.
    I used to pull out of a warehouse that was exactly the same way no lights no lock nothing. It's controlled 100% by paperwork. Once the driver is handed the paperwork it's assumed that the job is finished and the driver can pull out without a problem and if something does happen it's the fault of the fork truck driver that it happens to not the driver because well he was given the paperwork and was told it was fine to go.
    Grubby#1, Opus, zaroba and 10 others Thank this.
  5. Brandt
    Brandt Road Train Member
    4,403
    5,936
    Sep 17, 2012
    If they gave you the paperwork back and said you were good to go, I don't see how they can blame you. They signed paperwork because they got everything off the trailer.
    Grubby#1, Opus, zaroba and 6 others Thank this.
  6. Val_Caldera
    Val_Caldera Road Train Member
    2,569
    7,934
    Apr 2, 2021
    TARHEEL
    Had the same issue ONCE in Winston-Salem, NC, off of exit 103, Rt. 52.
    Backed to East side Dock with open secured trailer doors, inside people LOCKED Docking device therein initiating the RED light, then proceeded to whine about why I was there. Told me to pull off dock after giving GREEN light. Pulled straight off dock and personnel started YELLING to stop. Stopped 30+ feet and saw in mirror, passenger side, some clown was still IN trailer. Clown jumped out and I rolled to front (north side) dock. Their anger continued in office and ceased just before being emptied.
    Local shuttle from greensboro. did 5 that day. that was (full of) number 2.
    tscottme, Numb, MartinFromBC and 2 others Thank this.
  7. JoeTruck
    JoeTruck Heavy Load Member
    853
    3,393
    Mar 13, 2015
    LOWER 48
    It's not your fault. They said it is good to go.
    It's a big problem today with people who don't speak English.
    Opus, tscottme, JoeyJunk and 4 others Thank this.
  8. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    you are still responsible to make certain that you ARE good to go.
    get out, go back there and CHECK the trailer.
    can there still be an issue with this?
    sure, when you get a court summons for injuries.
    G.O.A.L. at all times....
  9. PaulMinternational
    PaulMinternational Road Train Member
    1,107
    5,478
    Aug 23, 2022
    Said its your Fault? The dock worker gave you the paperwork , told you you are good to go! Who's fault is it?
    I personally would have recorded the conversation with the boss and been adamant that he accept it wasn't my fault!
  10. Iemontel
    127
    71
    Jan 10, 2020
    mo
    yes i understand but would the worker win in court , after telling me I’m good to go and handing my paperwork ? Why would he jump inside the trailer ?
  11. Iemontel
    127
    71
    Jan 10, 2020
