So I've seen special commodities dryvan trailers for sale with low-profile tires. I assume this is to help with overhead height inside and door opening restrictions on a 13'6" trailer. Does that screw you up bumping docks? Do those guys carry around some blocks to drive the trailer tandems up onto to get them to dock height?
Also does anyone running drop deck van trailers (electronics vans, moving vans) have experience running freight in those same trailers? How much trouble does it cause turning up at shippers with the lower deck?
thanks guys
dock height, deck height, & trailer tires
Discussion in 'Experienced Truckers' Advice' started by mugurpe, Nov 5, 2016.
Water heater loads from an weber come in trailers with jack legs that rais the tail to dock hight
We've done work at a few auto parts plants that have docks with ramps for "high cube" trailers...
The plant near my house used to have a fleet of high cube trailers going in and out, but the docks are hidden.... -
Bakerman Thanks this.
I pull auto parts in drop deck van...
The shipper/receiver needs a special dock for it. A normal 10' door is not tall enough, it needs to be a 12' door. It also need to either be built for drop-deck, or have portable ramps to lift the deck up to dock height. Then there is the nose of the van. Depending on the van, you might have to run the 5th wheel all the way back to clear mud flaps, which limits the weight. And you cannot slide tandems either (at least on ours), so again weight limited. Another problem with the nose, is unless you have a place setup for it, you will loose some of that space. The racks I pull are about 5 foot wide. That leaves an empty space on the nose between the racks and the bukhead of the trailer. Gotta always stop gently.
Also, at least according to our shop, the tires, breaks, and drums are horribly expensive compared to 'regular' 22.5" tires.
To be honest unless you have customers lined up that needs a drop desk I cannot see how it would be worthwhile.
