Do you need to balance drive shaft?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Shotgun94, Feb 28, 2020.
  1. Shotgun94
    Shotgun94 Medium Load Member
    446
    301
    Sep 24, 2017
    Georgia
    So I’m doing I’m U-joints and carrier bearing as preventative maintenance.
    Do I need to get the drive shafts balanced as well?
    The drive shaft didn’t fall of so it’s not dented but was wondering your opinion.
    Thanks
    truckdriver31 and x1Heavy Thank this.
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Driveshafts are some of the most neglected items ever. If your new joints and so forth runs fine with the old shaft in place and that tractor is happy leave it be. If it's not? roll it on the ground to see where it's bent. If bent drop a new shaft on there.
    truckdriver31 Thanks this.
  4. AModelCat
    154,235
    If you've got no vibrations or reasons to suspect its out of balance (ie a weight appears to be missing) I wouldn't worry about it.
    pushbroom, truckdriver31 and x1Heavy Thank this.
  5. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    better make sure them joints are inline with each other. it will shake bad if not
    HoneyBadger67 and tow614 Thank this.
  6. Shotgun94
    446
    301
    Sep 24, 2017
    Georgia
    well, the joints and carrier bearing are bad, had a bad vibration and freeplay I could move with my hands.
    So with that, should I get it balanced still?
  7. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    are the weights still on the drive shaft. i have replaced joints and carrier before. and not balanced shaft
    Shotgun94 Thanks this.
  8. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    I most certainly would balance it if you have a complaint. I usually just let the driveline shop do the re joint and bearing change cuz it's worth the labor for them to just get er done.
    The other option is- mark the shaft before removal. Change all the parts and put it back the same way. If the shake is still there you could balance later.
    Typically if you mark and put it back you should never need a rebalance unless you shed a weight or something is bent.
  9. Shotgun94
    446
    301
    Sep 24, 2017
    Georgia
    I saw they are still on it, the stick on type weights.
    I don’t want to be cheap but also don’t want to spend money that doesn’t need spending. I had one shop tell me $125 to balance it depending on what is wrong with it and $35 per u-joint and I’m doing all the drive shafts bc i don’t want to have anything go bad later. And $125 for the carrier bearing. I got the parts bc I don’t want to be upcharged on the parts.
    Another shop shop said $20 per u-joint
    Cabinover101 and Rideandrepair Thank this.
  10. Shotgun94
    446
    301
    Sep 24, 2017
    Georgia
    Seeing how this is my first time doing this and I don’t want to have to do this twice i think I’ll send it off to the guy. He said he makes punch marks to show you the direction on reinstalling it.
    tow614 Thanks this.
  11. Shotgun94
    446
    301
    Sep 24, 2017
    Georgia
    Can you balance drive shaft while still on the truck or do you have to have it removed still?
    tow614 Thanks this.
