Do you drain the air tanks during post trip?
Discussion in 'Experienced Truckers' Advice' started by Lab work, Feb 24, 2020.
  1. Lab work
    Lab work Medium Load Member
    551
    674
    Apr 20, 2018
    USA
    Last week the truck I had went in the repair shop because I couldn't change to low range unless it was warmed up. Unfortunately the cylinder that changes the selected range was rusty and will only change after it is running for a while. I was informed by the mechanics it is because no one drains the air and the condensation caused the rust. I was issued the truck with over 800,000 miles.
    But now the company I drive for has provided me a different truck with only 155,000 miles. But it is automatic and I can not find the owner's manual anywhere. So I am wondering if I should incorporate the process of draining the air tanks on this truck when I do my post trip?
    Also if you or anyone you know plans on buying a used Freightliner with a standard transmission. Tell them to check the truck facts. If there is such a service. I don't know if checking the engine on one of those machines is capable of identifying a rusty transmission.
  3. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,079
    Sep 24, 2019
    Raleigh, NC
    Dealers choice when you drain them during the shift. Pick a time when it works for you and stay with it.
  4. Opendeckin
    Opendeckin Medium Load Member
    446
    1,241
    May 20, 2018
    Needs a new air dryer cartridge. I drain my air tanks out of curiosity once every 3 months or so and nothing ever comes out.
    kylefitzy, HoneyBadger67, PE_T and 3 others Thank this.
  5. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    I forget most of the time and hardly anything comes out when I do remember.
    PE_T and Lab work Thank this.
  6. PE_T
    PE_T Road Train Member
    How often you need to drain your air tanks depends on your air drier. My Bendix air dryer model says to drain every 25,000 miles or 3 months (whichever comes first).
    Lab work Thanks this.
  7. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,982
    18,763
    Mar 9, 2014
    In a van down by the River.
    I drain mine any time I know the temos will get into the 20s. During the summer I will drain them a few times a month.
  8. jeffman164
    jeffman164 Medium Load Member
    594
    557
    Dec 4, 2012
    I drain if super cold. Drain occasionally the rest of time.
  9. PE_T
    If you drain it when it’s under 30, it’s too late. The water is already frozen in the tanks. Small amounts of water freeze very quickly when in temps under 30 for a few hours.
  10. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    i had gotten into the habit of draining at the post trip inspection, from my first days. once you get into a habit, kinda hard to break it.
  11. jeffman164
    594
    557
    Dec 4, 2012
    I meant that I drain right away after stopping if it is going to be super cold.
    Lab work and PE_T Thank this.
