Do you chock wheels and release the parking brake to check slack adjusters?
Discussion in 'Trucking Schools and CDL Training Forum' started by Newtotrucking2020, Dec 3, 2019.
  1. Newtotrucking2020
    Newtotrucking2020 Bobtail Member
    25
    9
    Oct 8, 2019
    For the front adjusters or only the rear? On a straight truck.
  3. Dino soar
    Dino soar Road Train Member
    4,789
    26,858
    Dec 8, 2017
    For the front you can lock the brakes and check them.
    The back of the truck has Maxi spring brakes, those are the brakes that you have to chock the wheels and release the brakes to check them.
    Newtotrucking2020 Thanks this.
  4. LDLWells
    LDLWells Heavy Load Member
    782
    1,217
    Jan 14, 2019
    They make those little rubber rings that you can put on. Seems safer than getting under a vehicle without brakes set
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Bring a chalk marker with you. The schoolhouse kind.
    And a small ruler.
    Chock your vehicle. take brakes off. Make sure it aint trying to get out of chocks (Plural...) mark the stroke rods.
    Get back in and set parking brakes. Those marks you made should now be within what? 2 inches of your starting point?
    With automatic slack adjusters today and the end of the adjusting of manual brakes with a wrench decades ago I don;t worry about if this brake or that brake is out of adjustment. That fact will become self evident soon enough and be taken care of then.
    Newtotrucking2020 and Bean Jr. Thank this.
  6. O.Henry
    O.Henry Road Train Member
    1,108
    2,085
    Sep 1, 2012
    San Antonio,TX.
    Does pushing brake pedal to floor (Brakes released) adjust them?
  7. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    If the slack adjusters are working properly, yes.
    Also you can put transmission in gear if you don't have a wheel chock or block or curb or stone.
    Newtotrucking2020 and O.Henry Thank this.
  8. Newtotrucking2020
    25
    9
    Oct 8, 2019
    Appreciate the info. I've heard do it for front and back but the consensus is just chock and release brake for the rear. I wanted to make sure for my pretrip test.
  9. Newtotrucking2020
    25
    9
    Oct 8, 2019
    at 3:51 he states wheels chocked and brakes released for front
    3:36 he says the same
    I just want to be sure because I read examiners failing people for calling a gauge an indicator.
