Do tractors bobtailing have to enter the state scales?
Discussion in 'Questions From New Drivers' started by Hollywoodsaint, Apr 6, 2021.
  1. Hollywoodsaint
    Hollywoodsaint Light Load Member
    232
    221
    Jun 20, 2020
    Hollywood California
    I was curious as we have all bobtail without a trailer but do we have to enter the state scales as obviously we have no trailer and aren't loaded
    NavigatorWife Thanks this.
  3. Moosetek13
    Moosetek13 Road Train Member
    14,517
    17,973
    Nov 1, 2010
    Burnsville, MN
    Don't most weigh stations require any vehicle over 10,000 pounds to come in?
    Is your bobtail less than 10k? Doubtful.
  4. Diesel Dave
    8,516
    23,380
    Jan 20, 2010
    Hesperia, Ca.
  5. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Most states yes, a few states no.
    Just depends on what the state wants. Most are all CMV's. A few are all CMV over x weight rating. A couple are all vehicles over x weight rating.
    NavigatorWife, slow.rider and Kyle G. Thank this.
  6. Kyle G.
    Kyle G. Road Train Member
    3,754
    19,600
    Jan 23, 2016
    Eastern Iowa
    Just do what the signs say at that particular scale. If sign says all trucks must enter then there’s your answer.
    It doesn’t make any more sense than pulling onto the scale with an empty flatbed, but I do it all the time. LOL
  7. 201
    201 Road Train Member
    12,042
    24,575
    Apr 16, 2014
    high plains colorado
    I read any truck with a DOT#, has to stop. This includes rental trucks, as well. When I moved to Co. from Wis., I rented the smallest UHaul truck, a van front and small box type, I checked into that before leaving Wis. and while most states won't bother with a rental truck, Neb. was wide open at 2 am, and I wasn't the only rental truck in line. If you have nothing to hide, I'd pull in, even though, they probably won't stop you, unless there's an obvious safety issue, but just try and run by one. :biggrin_25513:
    Kamkor, NavigatorWife, Kyle G. and 2 others Thank this.
  8. roundhouse
    roundhouse Road Train Member
    3,129
    7,022
    Jul 11, 2018
    Florida will chase down rental box trucks if they don’t pull in the scale.
    I’ve seen it happen a lot.
  9. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
    Bobtail your still a cmv so YES
    NavigatorWife and slow.rider Thank this.
  10. Arctic_fox
    3,859
    19,392
    Sep 16, 2016
    IMO a good rule of thumb with any CMV or box vehicle is to pull in. Worst case they wave you through and are a bit annoyed.
  11. truckguy391
    truckguy391 Light Load Member
    129
    399
    Jan 22, 2017
    Around
    I always enter unless told otherwise. 99% of the time you’ll just get waived through. The only time I wasn’t was when a cop wanted to take a quick peak at my hours of service and that took literally 30 seconds
