I think my steering wheel might need tightened up? too much loose play in it before it responds?
I'm not a mechanic or anything.. is this a factor that needs adjusted sometime?
I'd like to do a good overall look at my truck.. Anybody have links to a guide to do that? thanks
Do some steering wheels have too much play in them?
Discussion in 'Questions From New Drivers' started by mikeposttown, Apr 21, 2019.
x1Heavy Thanks this.
It certainly can be an issue. If you get a level 1 DOT inspection It will be checked .
Write it up on your MVIR and tell the company about it.
Get it checked by a qualified mechanic, any play in a steering system=worn or loose parts, could be very detrimental to you or someone else's health.
Well, hold on, I drove trucks with 1/4 rotation of play and never killed anyone, however, excessive play is something to look into. Open the hood, there is a shaft going to the steering box. With truck running, grab the shaft and turn it slightly each way observing the rods it's connected to. You may see the worn part right away. There should be no play in the connecting points ( ball joints)
Canadianhauler21, speedyk and x1Heavy Thank this. -
There’s an actual amount that’s allowed, maybe 1” , I can’t remember, it refers to steering box only, that’s if all the front end parts are good.Anything can cause your issue, bad tie rod or pitman arm can be dangerous. Best get it checked out ASAP.
The steering lash cannot exceed roughly 2 inches and is based off a formula per steering wheel diameter.
49 CFR § 570.7 - Steering systems.
Oddly, many of the pre 2008 or so trucks have pretty sloppy steering even with all the ball joints and steering boxes tight.
First time I got into a modern truck, was a 2012 cascadia. The frigging steering was tighter than in my 2010 impala or the 2008 Silverado before then which was very tight for a truck then. Thusly, began my first true love of modern trucks.Canadianhauler21 and Rideandrepair Thank this. -
