Do reefers go into idle?
Discussion in 'Refrigerated Trucking Forum' started by Canadianhauler21, Jul 21, 2020.
  1. Canadianhauler21
    Canadianhauler21 Heavy Load Member
    842
    1,616
    May 15, 2017
    I have this weird thing that's happened over the last two trips where the reefer will be running but the temperature goes up.
    For example, today I had the reefer setpoint at -10F, I woke up and the reefer was running but the temperature was 5F. I turned it off and than back on and it started working normally again, no error codes or nothing.
    It's a thermo king reefer. It was set to continuous as well. Any idea if this is normal or am I missing something in the operation?
  3. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    the road less travelled
    Might have been in defrost when you caught the higher than normal temp while set so cold.
    88 Alpha, jbatmick, nredfor88 and 6 others Thank this.
  4. 062
    062 Road Train Member
    6,142
    33,155
    Oct 20, 2013
    It depends on how the parameters are set.
    They have a high speed delay and another is basically the temp which it kicks into high speed.
    Best just to write it up and get it checked out.
    Canadianhauler21 Thanks this.
  5. Canadianhauler21
    842
    1,616
    May 15, 2017
    That makes alot of sense actually, do these reefers go into defrost on their own usually?
    Thank you for your reply, I'm still a bit unfamiliar with reefers in general.
  6. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    Yes, they do, if working right.
    88 Alpha, Canadianhauler21 and bzinger Thank this.
  7. truckguy391
    truckguy391 Light Load Member
    129
    399
    Jan 22, 2017
    Around
    Probably just the defrost cycle. It’s perfectly normal and nothing to worry about. A lot of units have a light that turns orange or some kind of alert that will say it’s in defrost mode. Once it comes out of defrost mode you’ll see the temperature drop towards the set point again.
  8. Lennythedriver
    Lennythedriver Road Train Member
    2,204
    7,301
    Feb 14, 2020
    As others have already stated that’s definitely a defrost cycle. You don’t want that unit freezing up in there. You’ll get a code 10 and the thing will shut down completely and not run if the unit freezes up. It has sensors and goes into a defrost mode before this happens. Sometimes it takes a few minutes hence the temperature will rise a bit. But the unit knows it and it will quickly defrost and get the temperature back down.
  9. Canadianhauler21
    842
    1,616
    May 15, 2017
    Thanks everyone, I kinda figured it would be normal but I wasn't 100% sure. Looks like I can sleep well from now on. You guys have taught me more about reefers than my company has.
    25(2)+2, Cat sdp and truckguy391 Thank this.
  10. truckguy391
    129
    399
    Jan 22, 2017
    Around
    YouTube is another good source of info. You should be able to find some info about thermoking or carrier (whichever you’re company uses). There should be some videos of basic overviews and how to use some of the features.
  11. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,377
    6,499
    Oct 22, 2016
    North Dakota, Eh?
    It should say on the screen "defrost mode" or something close to that. And probably dumping defrost water out the right side if the unit.
    25(2)+2 and Canadianhauler21 Thank this.
