"Do Not Push" the dump truck
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by TheDude1969, Aug 27, 2016.
  1. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    This slow arse dump pulls out in front of me in single lane construction, and I'm thinking I'd like to push this sum'bich and I look up, there's my sign... Do Not Push. I'd didn't realize there was an epidemic of people pushing dump trucks, but I can understand why.
    Only kidding, but seriously... I see this sign on the back of dumps everywhere. I'm sure this is construction related, for the heavy equipment operator, but in what scenario would he want to push you?
    burnsey Thanks this.
  3. jason6541
    jason6541 Road Train Member
    2,425
    5,365
    Mar 5, 2012
    Omaha, NE
    If the dump gets stuck dumping material, or a soft spot in the construction area.
    TheDude1969 and Getsinyourblood Thank this.
  4. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Yep. Some trailers (steel ones, usually) are made with a push guard so a dozer can give you a push when you get stuck. Aluminum does not take kindly to that activity, so you have to tug on the front of the tractor instead.
  5. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    What about "Do Not Use Hooks".
    TheDude1969 Thanks this.
  6. Fatboy42
    Fatboy42 Light Load Member
    281
    389
    Feb 9, 2011
    Indiana
    A lot of excavator operators like to push on the tailgate to help you off the pile and bend the snot out of your tailgate
    wore out, TheDude1969 and ShooterK2 Thank this.
  7. TheDude1969
    807
    823
    Jun 10, 2013
    Joliet, Il
    Makes perfect sense not to push, I'm surprised that an operator would even try that. I've been stuck many, many times, pulling a flatbed, and it has always been my steers that dug in too deep. I could picture a slow motion jacknife... pull only makes sense
  8. scottied67
    scottied67 Road Train Member
    10,816
    12,615
    Mar 14, 2010
    california norte
    The mounts for the dump bed are designed for downward pressure not longitudal or lateral pressure. Plus pushing onthe dump bed pushes on that big hydraulic ram and that is definitely not designed for that.
    tucker and TheDude1969 Thank this.
  9. 201
    201 Road Train Member
    12,047
    24,586
    Apr 16, 2014
    high plains colorado
    Just for the record, that dump truck in a construction zone has the right of way. Years ago, before trucks were made out of tissue paper, the tail gate was indeed strong enough to be pushed. Truth be known, with 238 hp motors, there wasn't enough oomph to get you out of a hole with a load. Pushing with a shovel was totally ok.
  10. street beater
    street beater Road Train Member
    4,578
    20,669
    Apr 18, 2014
    cold as hell, MN
    Belly dumps have a push bump on the back, they get pushed all the time....
  11. korky
    korky Light Load Member
    97
    56
    Aug 14, 2013
    AZ
    When a dump truck backs up to the paving machine some contractors have hydraulic hooks with rollers that hook to the rear outside wheels to keep the truck from rolling away and dumping asphalt on the road instead of the machine's hopper. It scrapes up the wheels pretty good. Otto and Heritage, as well as some others, usually will have steel wheels on the rear axle and aluminums everywhere else, Mundall, Alan Harris and the other companies with nice trucks won't allow that.
